FezzaT Posted September 5, 2009 Share Posted September 5, 2009 Guys, quick question, on MK7's with EATC, if you set the temperature to say, 16°C, the air con comes on automatically as well. If you are then to swithc off the air con, the EATC continues to stay on, but is it still cooling to the original 16°C? ie does it NEED the air con to function correctly? ...does that make any sense?! Quote Link to comment Share on other sites More sharing options...
jma78b Posted September 5, 2009 Share Posted September 5, 2009 Guys,quick question, on MK7's with EATC, if you set the temperature to say, 16°C, the air con comes on automatically as well. If you are then to swithc off the air con, the EATC continues to stay on, but is it still cooling to the original 16°C? ie does it NEED the air con to function correctly? ...does that make any sense?! You are correct. It blows out cooler air at 16 degrees but it would need the full A/c on to get the better effect. I'm quite happy with it blowing out cool air at 16. Quote Link to comment Share on other sites More sharing options...
TitaniumSteve Posted September 5, 2009 Share Posted September 5, 2009 I hardly use the Automatic feature, I use either the air con alone or no air con on at all. I would guess using air con all time via the auto feature would knock your fuel consumption. If a car is below 50mph it is cheaper to open window, so if driving at higher than 50mph and want to be cool then air con is better on fuel than opening a window due to the drag of opening window. I know that because I saw it on Mythbusters, lol. Quote Link to comment Share on other sites More sharing options...
jma78b Posted September 5, 2009 Share Posted September 5, 2009 I love to turn it on when I get into a boiling hot car. Just for a little while until the temp inside goes down. The windows open just isnt enough. I only have 2 anyhow! Quote Link to comment Share on other sites More sharing options...
