DB6431 Posted August 20, 2015 Share Posted August 20, 2015 Although primarily on here as I own a 1997 Escort Ghia, my camper van has a Transit base, so please could I pick the brains of you good Transit owners. On a long run recently the water in fuel light came on intermittently while going up hill, it was raining heavily at the time, have tried to drain the filter as per manual but all that came out was a hiss of air, no water or fuel, is this normal as I was expecting a little water followed by some diesel Quote Link to comment Share on other sites More sharing options...
MONDEO TXS 2.2 Posted August 20, 2015 Share Posted August 20, 2015 Does it do it on level ground ? Or only when going uphill ? Quote Link to comment Share on other sites More sharing options...
DB6431 Posted August 20, 2015 Author Share Posted August 20, 2015 Yes only on an incline, and it did not stay on, just a couple of seconds every now and then Quote Link to comment Share on other sites More sharing options...
MONDEO TXS 2.2 Posted August 20, 2015 Share Posted August 20, 2015 You said it hissed - air has water in it - so maybe a tiny airlock when going uphill ? Quote Link to comment Share on other sites More sharing options...
DB6431 Posted August 20, 2015 Author Share Posted August 20, 2015 Maybe, do I need to be worried though Quote Link to comment Share on other sites More sharing options...
MONDEO TXS 2.2 Posted August 20, 2015 Share Posted August 20, 2015 There's obviously a fuelling issue somewhere, I'd take it to a diesel specialist Quote Link to comment Share on other sites More sharing options...
DB6431 Posted August 20, 2015 Author Share Posted August 20, 2015 Thanks, will get it checked to be safe Quote Link to comment Share on other sites More sharing options...
iantt Posted August 20, 2015 Share Posted August 20, 2015 When was the last time the fuel filter was changed? What engine is it? The older2.5 or 2.4 duratorq? Quote Link to comment Share on other sites More sharing options...
DB6431 Posted August 20, 2015 Author Share Posted August 20, 2015 It's the older 2.5td with 45 on the clock, runs like a dream, but unsure when filter was changed Quote Link to comment Share on other sites More sharing options...
iantt Posted August 20, 2015 Share Posted August 20, 2015 Didnt know they had water in fuel sensor on filter assy on 2.5, havent seen a 2.5 in a long time. Quote Link to comment Share on other sites More sharing options...
MONDEO TXS 2.2 Posted August 20, 2015 Share Posted August 20, 2015 Definitely change the fuel filter first before doing anything else or spending £ Quote Link to comment Share on other sites More sharing options...
