Mk3 Instrument Cluster Swap
Translation.
Hi guys I upgraded the IPC software to the mk3.5 version but I find myself with a problem after several turning the machine on and off the IPC resets the temporary values (kilometers, duration of freight, consumption, etc.) someone can help me please
  • 5 months later...
  • Replies 217
  • Views 97.4k
  • The original FoCCCus software has the 1000 miles limitation. To solve this I removed the 1000 Miles limitation and made a modified version of the FoCCCus software. My version can be downloaded from th
  • Technically all European Focus MK3 instrument clusters are compatible. There are only differences between Petrol or Diesel and KM/H or MPH. MK3.5 Instrument clusters have different firmware which is
  • On the MK3 the PATS system is integrated into the PCM and the BCM. The instrument cluster of the MK3 is not a part of the PATS system and can be changed without any problem.
hi sorry to revive an old thread, but does anyone know what part number I need for my parking sensors to still work for my mk3 pfl focus? its a 1.6 zetec petrol. thank you
  • 1 year later...
Hi all,
I have a Ford Focus Mk3 Zetec S 2012 with the 6 speaker audio system and the basic blue monochrome display. I don't believe i have SYNC 1 i think i have the bluetooth voice control one.
I was wondering if i installed a steering wheel with cruise control, would cruise control work?
Many thanks in advance,
Ben
The short answer is 'No'
Thank you for getting back to me. Is there any steps I can take to get it to work? For example swapping the instrument cluster?
Why not?
If your Body Control Module supports, cruise control then you can change the steering wheel, you may also have to change the clock spring (not sure on your exact model) and then use FORScan to make the changes needed to the BCM, and IPC.
I have used FORScan to check the Body Control Module and the option is available to change from "without cruise control" to "cruise control". I am unsure if that definitively means it is supported? I just haven't ever seen an image of cruise control being used on the small monochrome display.
Use FORScan and have a look at the instrument cluster options to see you can turn on the option of cruise.
Okay just checked the IPC Central Config (Backup) and cruise control option is present. I have included a screenshot. Also it seems my IPC is BM5T-14C025-AD if that helps.
Looks worth a try 👍
The only other issue is the clock spring, but if you need to replace it then you can do that when you change the steering wheel.
Okay i will give it a go. Thank you for your help! 👍
  • 4 months later...
On 6/2/2019 at 1:28 PM, JW1982 said:
Yes, this is also perfectly possible on a Kuga.
However you should be aware that despite looking identical the Kuga/Escape instrument clusters are different from the Focus/C-max instrument clusters.
Good day, can anyone share the programming instructions for the Kuga cluster for the Focus MK3 pre-facelift?
  • 9 months later...
Would anyone be able to help me locate the files to update the BM5T-10849-BLG cluster to 3.5 FW?
FORScan support, but only if you have a paid license
Hey Dave,
Yes I do indeed. I imagine I just get in touch with them?
Just now, asec said:
Hey Dave,
Yes, follow the instructions on the support page, you will need to include the logs
Dave,
That'd be the direct support tab on forscan's page right? Wasn't unfortunately able to find what section applies most to me. Thank you for the hassle...
