mk2 ford transit
kenko
:rolleyes:
Hi guys, need a little help if theres any old school boys here, just picked up a 1985 mk2 transit horsebox with a 2 ltr pinto engine under the bonnet but its running lumpy, susspect carb problem, can anyone recommend a decent but cheap carb I can put on. Any ideas would be appreciated, not looking to run it down santa pod in under 10, just a smooth drive would be great, with a little bit more power thats all. Cheers, Jason.
the 2lt pinto had a weber 32/36 DGAV carb fitted, you could try eBay or one of the many online breakers for a replacement.
ok, ive figured out this 2.0 ltr pinto engine does have a 32/36 DGAV carb fitted, Ive done a compression test just out of curiosity and got the following:-
No 1: 75 psi
No 2: 57 psi
No 3: 45 psi
No 4: 45 psi
did the test 3 times just to comfirm and always the same. i suspect there is a problem possibly headgasket between 3 & 4 cylinder, but the results seem very low generally, i was expecting maybe 140 to 160 psi? low compression engine maybe?
can anyone tell me how i can figure out if this is a low compression engine before i go any further?
cheers for now.
a perfect pinto would give 160psi so something is seriousley amiss so its time to get the spanners out.
