ElCani Posted April 5, 2016 Share Posted April 5, 2016 Having recently bought a 2013 Focus estate which has only a compressor and a can of sealant in the boot, I would like to swap these for a space saver spare wheel. Currently the sealant kit is held in a polystyrene moulding that sits in a space under the boot carpet which looks big enough for a space saver, but I was hoping someone could 100% confirm that it will fit? I notice on the Ford configurator for the MK3.5 a spacer saver is only an option on the hatch, not the estate. I'm hoping to buy this: http://goo.gl/Ht8z3K Thanks in advance. Quote Link to comment Share on other sites More sharing options...
Fkuk Posted April 5, 2016 Share Posted April 5, 2016 Shouldn't be too difficult to measure if it will fit. Measure the diameter of the space, and depth and does it have a mounting bolt to hold the wheel secure. Some MOT places might fail the car because of a unsecured spare wheel Quote Link to comment Share on other sites More sharing options...
ElCani Posted April 5, 2016 Author Share Posted April 5, 2016 Thanks, I will measure it, just wondered if anyone had actually done the swap. There is a mounting bolt that holds the polystyrene moulding, TBH it all looks like it should work: Quote Link to comment Share on other sites More sharing options...
mikeyd1 Posted April 5, 2016 Share Posted April 5, 2016 I have done this on a fiesta i took the foam out and put a space saver in job done 1 Quote Link to comment Share on other sites More sharing options...
mikeyd1 Posted April 5, 2016 Share Posted April 5, 2016 U will re use the mount bolt for ur space saver. Make sure u get the jack aswell Quote Link to comment Share on other sites More sharing options...
mjt Posted April 6, 2016 Share Posted April 6, 2016 My Mk3 estate has the space saver. It has a polystyrene moulded ring that sits on top to bring the level up and stop the boot floor panel from sagging. If you're going for a spare wheel why not get a full-size one? You won't be speed-limited if you need to fit it then. 1 Quote Link to comment Share on other sites More sharing options...
Fkuk Posted April 6, 2016 Share Posted April 6, 2016 I think there are 2 different sizes for the spare wheel space. I have a mk3 estate and with a space saver there is only 15mk3 between the wheel and carpet which ford has bridged the gap with polystyrene I believe etis says if you have full or space saver wheels Quote Link to comment Share on other sites More sharing options...
jeebowhite Posted April 7, 2016 Share Posted April 7, 2016 just remove the polystyrene insert and it will be a straight fit. You would then be best off buying a used polystyrene insert which sits under the space saver, and holds the tools. Quote Link to comment Share on other sites More sharing options...
mjt Posted April 7, 2016 Share Posted April 7, 2016 I've just measured the depth of the well on my Mk3. It's 160mm without the thin (~5mm) felt under the spare so the 215/55 R 16 wheel won't fit. I assumed the polystyrene ring made up the difference between the T125/80 space saver and the 215/55 standard wheel but obviously not. The poly ring is, indeed, 15mm thick. Quote Link to comment Share on other sites More sharing options...
jeebowhite Posted April 8, 2016 Share Posted April 8, 2016 you can either (if you are wanting to fit a full size spare) - purchase the (almost too rare) full size boot polystyrene moulding, or, go for a home job (as I did) and manufacture your own :P Quote Link to comment Share on other sites More sharing options...
