Danerel Posted April 30, 2016 Share Posted April 30, 2016 Hey guys! My windscreen washer hose has split and I need to do a replacement. However I can't seem to find anywhere that sells a replacement hose? If anyone else has had to replace where did you get yours? Or will a similar size vacuum hose do? Thanks :) Quote Link to comment Share on other sites More sharing options...
dezwez Posted April 30, 2016 Share Posted April 30, 2016 loads on here http://www.ebay.co.uk/sch/i.html?_from=R40&_trksid=p2050601.m570.l1313.TR3.TRC2.A0.H0.TRS0&_nkw=windscreen+washer+hose&_sacat=0 2 Quote Link to comment Share on other sites More sharing options...
artscot79 Posted April 30, 2016 Share Posted April 30, 2016 any pet shop with aquariums sells the same hose Halfords usually sell it ir bodge it a piece of tubing slightly larger than the washer hose a dab of glue slip both ends in and voila 3 Quote Link to comment Share on other sites More sharing options...
Danerel Posted May 1, 2016 Author Share Posted May 1, 2016 Thankyou very much for the replies guys! :) Would you happen to know the Diameter of the hose needed? I wont be back home until mid week to check but need to order the hosing :) Thanks! Quote Link to comment Share on other sites More sharing options...
simcor Posted May 1, 2016 Share Posted May 1, 2016 Yep Halfrauds do indeed sell it as would almost any motor factors too, getting the right size is the hardest bit. Quote Link to comment Share on other sites More sharing options...
