Jonanstee Posted May 4, 2016 Share Posted May 4, 2016 Hey guys. My speaker has blown but I can't work out how to remove the door panel to change it. I've followed one on penny's guides by removing the two bolts under the handle but can't work out what to do from there? Anyone know how to. I don't want it breaking but desperately need it off. thanks jonanstee Quote Link to comment Share on other sites More sharing options...
sean.kerwin Posted May 4, 2016 Share Posted May 4, 2016 On the back doors. There are small bolts on the bottom of the door I believe, I can't remember, but I do remember the 3 bolts from the handle and hen giving it a yank on the edges. It's held in place by alot of clips. Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
sean.kerwin Posted May 4, 2016 Share Posted May 4, 2016 Ps, have fun removing the riveted Speakers Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
Jonanstee Posted May 4, 2016 Author Share Posted May 4, 2016 So it's a case of after undoing the bolts just pulling it hard? Quote Link to comment Share on other sites More sharing options...
simcor Posted May 4, 2016 Share Posted May 4, 2016 Have a look in my signature there's a link to a PDF of a Haynes manual. At work on phone so can't have a look at it. Quote Link to comment Share on other sites More sharing options...
sean.kerwin Posted May 4, 2016 Share Posted May 4, 2016 That's how I did it Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
simcor Posted May 4, 2016 Share Posted May 4, 2016 They are usually held on with body clips around the edges. Yanking it off will very likely break the clips and you can damage the door panel doing so. Use a long bladed screwdriver or pry bar to get under the panel around where the clips are and prise them out one by one is the best way of doing it. You can buy trim removal tools to do this also like a forked pry bar basically. 1 Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted May 4, 2016 Share Posted May 4, 2016 Trim tools are very handy. I prefer Bojo. Sent from my SM-G930F Quote Link to comment Share on other sites More sharing options...
