dannyb Posted January 18, 2017 Share Posted January 18, 2017 Hi, after scouring the net I haven't been able to find a fault like mine. So wanted some advice if poss. I have owned my 06 Fiesta Tdci for over three years. It has always had a lag when pulling away. Also when stationary and out of gear, if you rev it, there is a noticeable delay in pick up. This can be a problem when pulling away at a junction, you need to get the revs op first before dropping the clutch. Once it gets to around 2k revs, it's fine. The issue hasn't worsened in over 3yrs, which tells me it's something and nothing. Any ideas?? I have just read an write up where a guy removed the airflow box and replaced it with a cone filter. He then unplugged the 'dosser valve'? He said this solved his lag/pick up. Feasible? Thanks 👍🏻😎 Quote Link to comment Share on other sites More sharing options...
DieselPig Posted January 18, 2017 Share Posted January 18, 2017 Check the rubber pipe from the turbo to the waste-gate, it can split, if you take the air inlet pipe off can you see the turbo spinning? Quote Link to comment Share on other sites More sharing options...
