Fiesta MK4/MK5 not starting
Hi all,
I've got a bit of a problem with my Fiesta not starting.  When you put the key in and turn it there's no response from the dash (no lights or anything). Turning the key all the way does absolutely nothing (pump not priming, not clicking etc.).  The interior light works and the horn but as far as I can tell nothing else is working!!
I've tried a spare key and swapping the relays under the bonnet around and still not getting anything.
Battery has been tested and is fine.
Does anyone have any ideas?  I'm suspecting the ECU has died for some reason.
Also does anyone have a diagram for the under bonnet fuse box? I think I may have put one of the small fuses back in the wrong place when checking them...
