SunRod Posted April 14, 2017 Share Posted April 14, 2017 I found this wire sitting loose when I took my battery out. I couldn't see anywhere that it was attached to or had come away from & the car seems to be running fine without it. Any ideas what it is? Cheers. Quote Link to comment Share on other sites More sharing options...
Lenny Posted April 14, 2017 Share Posted April 14, 2017 2 hours ago, SunRod said: I found this wire sitting loose when I took my battery out. I couldn't see anywhere that it was attached to or had come away from & the car seems to be running fine without it. Any ideas what it is? Cheers. MAF sensor "Mass Air Flow" If it is it should be in the induction box to check the temperature of the air being taken in to the engine, Perhaps its the remains of an old one Quote Link to comment Share on other sites More sharing options...
iantt Posted April 14, 2017 Share Posted April 14, 2017 nope, thats remains of heated windscreen ribbon on one end of that cable from what i can see. so either the heated screen doesnt work one side or a replacement screen has been fitted at some point. 1 Quote Link to comment Share on other sites More sharing options...
Lenny Posted April 14, 2017 Share Posted April 14, 2017 1 hour ago, iantt said: nope, thats remains of heated windscreen ribbon on one end of that cable from what i can see. so either the heated screen doesnt work one side or a replacement screen has been fitted at some point. Spot on 👍 we will keep you on the plaine 😀 Quote Link to comment Share on other sites More sharing options...
iantt Posted April 14, 2017 Share Posted April 14, 2017 Even on my hols , i can be of help. Lol 1 Quote Link to comment Share on other sites More sharing options...
