cbirchy87 Posted July 11, 2017 Share Posted July 11, 2017 So my poor focus has another issue just days after fixing her power steerings. The car is misfiring! on cylinder 2. Opened up the spark plug well and they have water inside, rusty water I have cleans most of it out but its still miss firing! Should i go ahead and replace the sparks? what else could this be? OB showed a misfire Something to do with ruinning above stalling speed and something about air fuel mix. I really hope its only the sparks! I have never replaced them. Quote Link to comment Share on other sites More sharing options...
cbirchy87 Posted July 11, 2017 Author Share Posted July 11, 2017 Forgot the say the misfire happen more then i put my foot down. Quote Link to comment Share on other sites More sharing options...
dezwez Posted July 11, 2017 Share Posted July 11, 2017 your plugs may well be rusted in good luck removing them 1 Quote Link to comment Share on other sites More sharing options...
cbirchy87 Posted July 11, 2017 Author Share Posted July 11, 2017 oh NO! Quote Link to comment Share on other sites More sharing options...
Devonboy Posted July 11, 2017 Share Posted July 11, 2017 Deepest sympathy Quote Link to comment Share on other sites More sharing options...
FatHead1979 Posted July 12, 2017 Share Posted July 12, 2017 Unfortunately the leaky screenwasher jets is a known MK2 issue, you (or however does the work for you) needs to be really patient and careful when trying to remove the spark plugs otherwise it's a head off job Quote Link to comment Share on other sites More sharing options...
cbirchy87 Posted July 12, 2017 Author Share Posted July 12, 2017 I have what i really, really hope is good news. Replaced the spark plug in cylinder 2 in the auto parks car park. The car didn't misfire once on the way home. I did have a fight getting the remaining 3 off. but i managed it with no issues. the only casualty was the tool i brought for the job, it was cheap! I have attached a photo of the sparks. I really hope this fixed the problem. Re: the washer jets. I know of this already :D I guess i just buy some new jets? 1 Quote Link to comment Share on other sites More sharing options...
Russ Posted July 12, 2017 Share Posted July 12, 2017 You can remove the jets, clean the area and put a little sealant on them when you replace the jets in the bonnet apertures, or you can buy new jets with seals on them. Quote Link to comment Share on other sites More sharing options...
cbirchy87 Posted July 12, 2017 Author Share Posted July 12, 2017 Ill use some sealant. but i will order some new shinny news one :) thank you Quote Link to comment Share on other sites More sharing options...
dezwez Posted July 12, 2017 Share Posted July 12, 2017 you were lucky getting them out well done Quote Link to comment Share on other sites More sharing options...
