JustinD Posted July 20, 2017 Share Posted July 20, 2017 Hi All, New member here, looking for help with my wife's 2013 Mk3 1.0 which is having some serious problems. The car is currently in and out of garages with our warranty company, but the cause of the issue has still not been found. The car would drive fine for around 2 weeks, then when starting, struggle for revs. eventually the car would not start at all, just cranking/turning over: Videos of problem The garages perform various tests, diagnostic checks, etc and only find that the spark plugs are cracked, no error codes, they replace the plugs and we get the car back. 2 weeks of normal driving again, and the same issue returns. Any help at all, as to what might be causing this would really be appreciated, we are really stuck at the moment... Justin Quote Link to comment Share on other sites More sharing options...
Ryan_Tango Posted July 20, 2017 Share Posted July 20, 2017 Just at a quick glance in the Haynes Manual it says battery terminal connections loose or corroded Ignition components damp or damaged Fuel injection system fault Major mechanical failure (eg, timing belt) Their is a few others listed but not relevant after watching the video. I'd suggest talking to your warranty company about getting the car repaired by Ford themselves as with all the trouble you're having is just beyond a joke. I hope this is some help to you if you need more information I can take pictures of pages from the manual for you. Quote Link to comment Share on other sites More sharing options...
JustinD Posted July 20, 2017 Author Share Posted July 20, 2017 Hi Ryan, Thanks for those suggestions. Regarding Ford, Ford were the 2 garage to take a look, and just change the spark plugs, ensuring us this was the problem. I definitely no longer Trust, Trust Ford. It is now with an extremely professional approved Ford Specialist, who have re-created the problem, but still struggling to find the cause. It seems so strange that it works perfectly after this, but only for a limited time. oh and to note, the car only has 19k miles on it!!! Quote Link to comment Share on other sites More sharing options...
Tasape Posted July 21, 2017 Share Posted July 21, 2017 I would thing it is time to return it as unfit for use , contact Ford customer service on their website, and Challenge them , Quote Link to comment Share on other sites More sharing options...
Phil21185 Posted July 21, 2017 Share Posted July 21, 2017 Quite a few folk seem to be having deadly problems with the eco boost engines, there's a post where someone had to have the engine replaced and because he had it done at an independent he had to shoulder over £4k in costs as Ford wouldn't honour the warranty Also, there was a recall recently bit I think that was just for the 1.5's. Might be worth checking ETIS for yours, otherwise agree with Tasape and hand it back... Quote Link to comment Share on other sites More sharing options...
FatHead1979 Posted July 22, 2017 Share Posted July 22, 2017 On 21/07/2017 at 10:52 PM, Phil21185 said: Also, there was a recall recently bit I think that was just for the 1.5's. Wasn't that for the 1.5 diesel not petrol? (i.e not an Ecoboost engine) 1 Quote Link to comment Share on other sites More sharing options...
iantt Posted July 22, 2017 Share Posted July 22, 2017 sounds like a fueling problem. either the intank fuelpump (most likely ) or the high pressure fuel pump. can the ford specialist not check the fuel pressure on diag equipment? 1 Quote Link to comment Share on other sites More sharing options...
v530anh Posted July 23, 2017 Share Posted July 23, 2017 I think there is a page on Facebook dedicated to ecoboast problems, over 400 members. https://m.facebook.com/groups/1738834536386432?multi_permalinks=1934631966806687¬if_t=group_activity¬if_id=1500751087623277&ref=m_notif Quote Link to comment Share on other sites More sharing options...
DJ_Andy_M Posted July 23, 2017 Share Posted July 23, 2017 13 hours ago, 1979Damian said: Wasn't that for the 1.5 diesel not petrol? (i.e not an Ecoboost engine) This was for the 1.5 diesel yes. Quote Link to comment Share on other sites More sharing options...
Phil21185 Posted July 23, 2017 Share Posted July 23, 2017 8 hours ago, DJ_Andy_M said: This was for the 1.5 diesel yes. My bad. Hope op gets sorted anyways Quote Link to comment Share on other sites More sharing options...
mjt Posted July 24, 2017 Share Posted July 24, 2017 On 23/07/2017 at 2:04 AM, v530anh said: I think there is a page on Facebook dedicated to ecoboost problems, over 400 members. As someone with a 1.0L 125ps Ecoboost that makes quite worrying reading. Quote Link to comment Share on other sites More sharing options...
alexp999 Posted July 24, 2017 Share Posted July 24, 2017 On 23/07/2017 at 2:04 AM, v530anh said: I think there is a page on Facebook dedicated to ecoboast problems, over 400 members. https://m.facebook.com/groups/1738834536386432?multi_permalinks=1934631966806687¬if_t=group_activity¬if_id=1500751087623277&ref=m_notif Only 400 for the tens of thousands sold? Less than 1%, sounds pretty good to me. No product is free of failures. 2 Quote Link to comment Share on other sites More sharing options...
mjt Posted July 24, 2017 Share Posted July 24, 2017 No, indeed, and the people who frequent the discussion groups are generally those who've had problems. However, the comments about the engine being designed to run at a higher temperature and the possible long-term effects of that could be a cause for concern. To run at a higher temperature requires a higher coolant pressure and we already know that has caused problems with cracking of the reservoir and that the ECU can't detect overheating quickly enough to avoid engine damage in the event of coolant loss. It ought to have been fitted with a CHT sensor. 1 Quote Link to comment Share on other sites More sharing options...
alexp999 Posted July 24, 2017 Share Posted July 24, 2017 They've made changes to it over the years, all come with the electric overrun coolant pump now for example. The software update as part of the recall also adjusted the parameters to try and stop it overheating, or at least warn you or go limp earlier to protect the engine. Quote Link to comment Share on other sites More sharing options...
mjt Posted July 24, 2017 Share Posted July 24, 2017 1 minute ago, alexp999 said: all come with the electric overrun coolant pump now for example All well and good but my understanding is that's just to prevent the turbo overheating and what about the thousands of older cars, including mine, that are running without that upgrade? Quote Link to comment Share on other sites More sharing options...
alexp999 Posted July 24, 2017 Share Posted July 24, 2017 2 minutes ago, mjt said: All well and good but my understanding is that's just to prevent the turbo overheating and what about the thousands of older cars, including mine, that are running without that upgrade? It's something you can add yourself. Ford have made it mandatory when installing a tow-bar. I think the pump is for the Turbo, but just an example of how they tweaked it over the years. I still believe the 1.0 ecoboost is more reliable than the old DV6. 1 Quote Link to comment Share on other sites More sharing options...
FatHead1979 Posted July 24, 2017 Share Posted July 24, 2017 17 minutes ago, alexp999 said: It's something you can add yourself. Ford have made it mandatory when installing a tow-bar. I think the pump is for the Turbo, but just an example of how they tweaked it over the years. I still believe the 1.0 ecoboost is more reliable than the old DV6. That wouldn't be very hard would it? 1 Quote Link to comment Share on other sites More sharing options...
mjt Posted July 24, 2017 Share Posted July 24, 2017 Sorry, my comments have taken the thread off-topic. Suffice to say the time is past when I would feel able to contemplate such a job. Surely the pump will need configuring in the ECU anyway? Quote Link to comment Share on other sites More sharing options...
alexp999 Posted July 24, 2017 Share Posted July 24, 2017 12 minutes ago, mjt said: Sorry, my comments have taken the thread off-topic. Suffice to say the time is past when I would feel able to contemplate such a job. Surely the pump will need configuring in the ECU anyway? Yeah it needs fitting and programming. Local dealer quoted about £300-350 for my mum's car iirc. When I said yourself I meant it's something that can be retro-fitted, rather than having to be from the factory. Ford have a TSB for it. Quote Link to comment Share on other sites More sharing options...
iantt Posted July 24, 2017 Share Posted July 24, 2017 I fitted the extra electric coolant pump, and it does kick in sometimes. There was a different pcm update for coolant pump . Quote Link to comment Share on other sites More sharing options...
JustinD Posted July 25, 2017 Author Share Posted July 25, 2017 Hi All, Just an update here. still no luck yet. this was not bought from Ford so cannot speak to them, if we don't get an answer soon it will be going back to the dealer we purchased it from. the specialist are current running tests on coil packs. my suspicion however is that it is something fuel based, as IanTT suggested. either pump or pressure sensor. Quote Link to comment Share on other sites More sharing options...
