liamstears Posted February 22, 2018 Share Posted February 22, 2018 Hope someone can help I retrofit an aftermarket rear camera, worked perfect Came across a genuine camera for a good price so decided to go for it Fit it including the BCM wire for steering input Now have an issue, please see: https://youtu.be/QaonPrSufi4 Camera does work sort of but pressing zoom it goes a bit mad and it does occasionally flicker on the normal screen, BCM functions work perfectly though Odd thing is if I put my finger on the bottom right of the lens it works, also if I move the position of the camera to point up instead of down it also works perfectly I decided it was a faulty camera so got another and now have 2 used cameras but both seem to have the same issue? So I'm thinking maybe it's not the camera, what else could cause this? Could it be that I am using just the 2 pins for video to the display? Genuine cameras have a 3rd shield cable that goes to pin 6 on the camera, could this be the issue? I do plan on adding that cable but wondered if I could get some input first hopefully from someone that has retrofit a genuine camera? Quote Link to comment Share on other sites More sharing options...
Jonro2009 Posted February 23, 2018 Share Posted February 23, 2018 I take it both cameras improve when you push the right corner or point it upward? I was going to suggest an Earth/grounding problem but it seems unlikely. Have you been able to try the camera without it in the position it is meant to be in, like just hanging off the end of the loom? Quote Link to comment Share on other sites More sharing options...
liamstears Posted February 23, 2018 Author Share Posted February 23, 2018 Yeh have tried, exactly the same result I did manage at 1 point to have it working normally in the normal position for a few seconds but when putting it all back together it wasn't working again Haven't been able to replicate Have tested the clip that goes into the camera by checking continuity on an electrical meter using some fuse wire in each of the 6 pins and that seems fine and hopefully if my new connector comes for behind the screen I'm going to replace the run from the screen to the camera and make sure I fit the shielding also Other than this I don't know what else it could be other than 2 faulty cameras, shame I haven't got 1 laying around I know works 100% although the seller of the cameras assures they are both fine and they are a trustworthy seller Quote Link to comment Share on other sites More sharing options...
ThaiFiesta Posted February 23, 2018 Share Posted February 23, 2018 Which screen do you need for the factory camera to work? Quote Link to comment Share on other sites More sharing options...
liamstears Posted February 25, 2018 Author Share Posted February 25, 2018 Fixed it! Replaced cable from screen to boot using a new 2 core shielded cable and connected the shielding properly and it works perfectly! As for the above question I'm using the 5" sat nav mfd low display that has a 4 pin hsd connector for the camera 1 1 Quote Link to comment Share on other sites More sharing options...
Jonro2009 Posted February 26, 2018 Share Posted February 26, 2018 Nice one Liam, you will be pretty pleased with yourself now. Good problem solving skills there bud! Quote Link to comment Share on other sites More sharing options...
bigchunk Posted February 26, 2018 Share Posted February 26, 2018 Hi Liam, I retrofitted the genuine ford camera to mine too, but my lines don't move and I don't have zoom function, the only wire I have not connected is the one from the camera to the BCM as I don't know what wire it is and where it connects to on the BCM. if you could give me any info on this wire it would be very much appreciated. Quote Link to comment Share on other sites More sharing options...
liamstears Posted February 26, 2018 Author Share Posted February 26, 2018 Sure Can't give you the wire color right this second but follow these steps for now Take out your parcel shelf, from the boot on the left hand side remove the trim, first the light color piece next to the headliner, there is 1 screw close to the passenger door behind a little cover you have the pry off, once the screw is out the trim will pull off Then remove the grey piece on the left, 1 screw close to the boot side and then it pulls off Them pull the carpet away Now at this stage you should see a big grey connector block near the seat belt mechanism This block pulls away from the car for easier access Now IF the wiring is already in place you should see that the top part of this connector which runs to the boot should have 3 wires missing, these are the 3 that would normally be for the camera, the bottom part of the connector which runs into the car hopefully has the 3 wires in place, mine did If the 3 wires are in place that's your 12v and ground for power and the BCM wire, not 100% sure off the top of my head but I think it was the middle one for BCM Check these are there first and if they are I will find out which one you need 1 Quote Link to comment Share on other sites More sharing options...
bigchunk Posted February 27, 2018 Share Posted February 27, 2018 Cheers for that! I'm at work abroad just now, will check it out when I get back to the UK. Quote Link to comment Share on other sites More sharing options...
