denny Posted March 24, 2013 Share Posted March 24, 2013 hi does anybody know where im going wrong. i have fitted a dvd player in my ka. i have used the correct plugs. but for some reason the player wont hold the setting in the memory. i have tried changing the red lead and the yellow lead with no different results. i was wondering if anyone else has had this problem. Quote Link to comment Share on other sites More sharing options...
RickG Posted March 24, 2013 Share Posted March 24, 2013 Maybe have the battery tested? Have you noticed anything else regarding starting the car etc? Quote Link to comment Share on other sites More sharing options...
denny Posted March 24, 2013 Author Share Posted March 24, 2013 rick g, i have tested the battery, it test fine how i tested because of starting problems. sometimes it starts fine, and others its a struggle. everything else works fine though. Quote Link to comment Share on other sites More sharing options...
mintalkin Posted March 24, 2013 Share Posted March 24, 2013 does the player need to have a permanent live feed to hold the memory, check to see you have this if the player needs it. Quote Link to comment Share on other sites More sharing options...
btmaldon Posted March 24, 2013 Share Posted March 24, 2013 Seems strange if you have swopped the red and yellow leads over and its still not holding the memory. You need to test that you still have a permanent live from the car to the unit. A fuse may have blown while you were connecting it up and only the switched live is powering the unit. Quote Link to comment Share on other sites More sharing options...
Preee Posted March 24, 2013 Share Posted March 24, 2013 It is missing it's Perm live for sure as btmaldon says check for a Premanent live. Quote Link to comment Share on other sites More sharing options...
