Fiesta 1.4 2004
Recently had a problem with the Fiesta... It suddenly started running very rough & engine warning light came on, called RAC who said it showed a fault on CYL 4 & it was only running on 3 CYLs. Turned out to be coil failure so I replaced coil/spark plugs & ignition leads & whilst it's much better it now seems slightly hesitant during acceleration sometimes..
my thoughts are maybe the fuel filter or the MAF / Lamba sensor have been affected by the coil failing ?
All advice appreciated
simon
Fiesta 1.4 "rough running" after new coil/plugs/leads
Started by simonkit, Aug 21 2008 06:16 PM
2 replies to this topic
#1
Posted 21 August 2008 - 06:16 PM
#2
Posted 21 August 2008 - 10:14 PM
Try resetting the ECU by pulling out the appropriate fuse. I don't know which one it is without looking it up in the manual.
#3
Posted 22 August 2008 - 07:29 AM
Thanks for the reply......
thing is that I did this, disconnected the battery for 30 minutes, it cleared the engine management light.
It seems too much of a coincidence that a sensor etc would fail at the same time as the coil ??
simon
