Water Problems
2 replies to this topic
#1 Ian Purdie
Ian Purdie
    Newbie
  • New Member
  • Pip
  • 1 posts
  • Ford Model: Mondeo
Posted 06 September 2010 - 02:08 PM
My Mondeo diesel 115 bhp has developed a fluctuating water temp reading. It reaches normal running temp but then drops down when the car is on over run or light throttle. It only comes back up under load. Have checked water level which was OK. Can anybody throw any light on my problem?
Have something to contribute?
#2 mintalkin
mintalkin
  • True Ford Enthusiast
  • PipPipPipPipPip
  • 3,558 posts
  • Name: mintalkin
  • Ford Model: mondeo tdci 130
  • Year: 2006
Posted 06 September 2010 - 02:36 PM
this is common on the tdci and is usually down to a thermostat problem, what people do not realise is that there are two thermostats,the normal coolant one and an oil cooler one,its usually the oil cooler thermostat which plays up.
#3 reinaldo
reinaldo
    Member
  • New Member
  • PipPip
  • 10 posts
  • Ford Model: Ranger
Posted 21 September 2010 - 03:43 AM
The problem might be in the ABS connector which leads to ABS lights on. Give ABS a ground circuit. This might solve the problem. If not, then check the thermostat.
Not what you're looking for?
