jocojohn Posted December 3, 2010 Share Posted December 3, 2010 Hi, my partner has a Ka luxury 52 plate, just recently the brake warning light has come on intermittantly mainly when applying the footbrake. I have checked the fluid level which was ok but I noticed the light comes on when the handbrake is only slightly applied ( about 1/4 inch movement ) Is it possible to adjust the play in the handbrake switch to see if this cures the problem. I dont have a manual at the moment, is there much envolved to get at the switch. Also, on a different topic, her car has began to stall at junctions, it always restarts first time. I`m going to remove the ISCV and clean it with Carb cleaner. What is the best method for cleaning? , ie to leave it soaking in cleaner or scrub with toothbrush etc etc. Thanks in advance, John Quote Link to comment Share on other sites More sharing options...
tommy.h Posted December 9, 2010 Share Posted December 9, 2010 Hi John check the tension on the handbrake cable. tom Quote Link to comment Share on other sites More sharing options...
