Shiplu Posted June 29, 2011 Share Posted June 29, 2011 Hi Guys, Any idea from where Pink Coolant is very slowly Leaking and filling up spark plug hole in 2005 1.6 Ford Focus Zetec Climate Auto? Could it be rocker (valve) cover gasket? Or something elese? This is causing rust in cylinder head where spark plug fits. Ccan it lead to a serious problem? Quote Link to comment Share on other sites More sharing options...
btmaldon Posted June 29, 2011 Share Posted June 29, 2011 Not sure where the core plugs are on the Focus, as Ive never had to look, but I remember on my old Puma, these were between the spark plugs and had a tendancy to leak. Its best to remove and replace, as they are not likely to be tightened. Also, you may have to get the local garage to do it, as they can be a real mare to undo. Quote Link to comment Share on other sites More sharing options...
stef123 Posted June 29, 2011 Share Posted June 29, 2011 are you sure its coolant? there is known issues with the washers leaking and allowing rain water in.. EDIT: just realised you said pink coolant..duhh. Hope its not a cracked head :( Quote Link to comment Share on other sites More sharing options...
Shiplu Posted July 1, 2011 Author Share Posted July 1, 2011 are you sure its coolant? there is known issues with the washers leaking and allowing rain water in.. EDIT: just realised you said pink coolant..duhh. Hope its not a cracked head :( Ya i know about the water jet issue and i have made a DIY engine cover, but its not the washer jet leak, its pink coolant that worries me! Quote Link to comment Share on other sites More sharing options...
Shiplu Posted July 1, 2011 Author Share Posted July 1, 2011 Not sure where the core plugs are on the Focus, as Ive never had to look, but I remember on my old Puma, these were between the spark plugs and had a tendancy to leak. Its best to remove and replace, as they are not likely to be tightened. Also, you may have to get the local garage to do it, as they can be a real mare to undo. What is core plugs between the spark plugs? I think there is something between two plugs on each side and looks really rusty and have more water on it. Quote Link to comment Share on other sites More sharing options...
btmaldon Posted July 1, 2011 Share Posted July 1, 2011 What is core plugs between the spark plugs? I think there is something between two plugs on each side and looks really rusty and have more water on it. Its usually a round silver bolt/screw that is about an inch in diameter, with a hexagonal hole in the top for a large allen key to fit into it. 1 Quote Link to comment Share on other sites More sharing options...
jeebowhite Posted July 2, 2011 Share Posted July 2, 2011 as stupid as it sounds, pour a bit of coca cola onto a sponge and leave it to sit over the rusty bit for a while, then wipe off and pour cola straight onto it, that should loosen it up, and take off enough rust to give you more of an idea as to what it is! I havent heard of coolant in the plug holes so I hope its nothing too serious, hopefully a case of a clumsly last owner who stood a bottle of coolant on the engine block and it spilled onto the head and drained into the plugs? Quote Link to comment Share on other sites More sharing options...
btmaldon Posted July 2, 2011 Share Posted July 2, 2011 as stupid as it sounds, pour a bit of coca cola onto a sponge and leave it to sit over the rusty bit for a while, then wipe off and pour cola straight onto it, that should loosen it up, and take off enough rust to give you more of an idea as to what it is! I havent heard of coolant in the plug holes so I hope its nothing too serious, hopefully a case of a clumsly last owner who stood a bottle of coolant on the engine block and it spilled onto the head and drained into the plugs? Its amazing what you can do with Coca Cola. Does make you wonder what it does to your insides though. 1 Quote Link to comment Share on other sites More sharing options...
cagohash14 Posted July 15, 2011 Share Posted July 15, 2011 I have a 1.6lx that had the same problem; it was the core plugs that were corroded, they cost 87p each from Ford and took a garage to 2 hours to fix; replaced my ht leads and spark plugs and blasted the car on the motorway problem fixed Quote Link to comment Share on other sites More sharing options...
Andy Cartwright Posted December 12, 2018 Share Posted December 12, 2018 I have the same problem with my 1.6 focus. Where is the pink coolant coming from? Don't understand why it would have anything to do with the core plugs, surely it would be leaking engine oil from there not coolant? Thanks in advance! Quote Link to comment Share on other sites More sharing options...
Lenny Posted December 12, 2018 Share Posted December 12, 2018 24 minutes ago, Andy Cartwright said: I have the same problem with my 1.6 focus. Where is the pink coolant coming from? Don't understand why it would have anything to do with the core plugs, surely it would be leaking engine oil from there not coolant? Thanks in advance! How pink is it? Could be Patina which looks pink but not, Are you noticing a drop in coolant resivour or white showing on the inside of the oil cap? Quote Link to comment Share on other sites More sharing options...
Andy Cartwright Posted December 12, 2018 Share Posted December 12, 2018 Hi Lenny, it's definitely pink. I read all the comments about water getting into the spark plug wells and presumed that's what it was. I had a garage replace the spark plugs a couple of weeks ago, all was fine until the engine light came on again last night, I pulled out the HT leads and sure enough its full of liquid again. I stuck a white rag down into the spark plug well and the liquid is 100% pink :-( This is actually the 3rd time in 2 years that I've had this problem, the first garage I took it to snapped a spark plug in the engine block which ended up being very costly! Thanks, Andy Quote Link to comment Share on other sites More sharing options...
Andy Cartwright Posted December 12, 2018 Share Posted December 12, 2018 I have noticed a drop in coolant level this morning yeah, I'll check the oil cap on my lunch break. Andy Quote Link to comment Share on other sites More sharing options...
mjt Posted December 12, 2018 Share Posted December 12, 2018 1 hour ago, Andy Cartwright said: Don't understand why it would have anything to do with the core plugs, surely it would be leaking engine oil from there not coolant? Core plugs are used to seal the holes where the supports for the cores used in casting the coolant spaces inside the block and head come out so they're nothing to do with the lubrication system.. 2 Quote Link to comment Share on other sites More sharing options...
Andy Cartwright Posted December 12, 2018 Share Posted December 12, 2018 2 minutes ago, mjt said: Core plugs are used to seal the holes where the supports for the cores used in casting the coolant spaces inside the block and head come out so they're nothing to do with the lubrication system.. Thanks Mike, I'm no engineer but I'm starting to understand this now! ;-) 1 Quote Link to comment Share on other sites More sharing options...
Andy Cartwright Posted December 12, 2018 Share Posted December 12, 2018 I managed to get a couple of photos so you guys can see whats going on. It looks like the garage have replaced some of the core plugs last time it was there. Quote Link to comment Share on other sites More sharing options...
Andy Cartwright Posted December 14, 2018 Share Posted December 14, 2018 Anybody have any advice for this? Thanks Quote Link to comment Share on other sites More sharing options...
Botus Posted December 14, 2018 Share Posted December 14, 2018 are u winding us up? one picture is of the oil filler cap? if it just had the oil changed and the variety of oil used was coloured pink.... water is water, water with pink antifreeze is still very much like water but a little more slippery engine oil is engine oil 1 1 Quote Link to comment Share on other sites More sharing options...
Andy Cartwright Posted December 18, 2018 Share Posted December 18, 2018 Lenny asked if there was white showing on the inside of the oil cap. I haven't had the oil changed. The engine coolant is pink, I haven't used any antifreeze yet this year. Quote Link to comment Share on other sites More sharing options...
Lenny Posted December 18, 2018 Share Posted December 18, 2018 39 minutes ago, Andy Cartwright said: Lenny asked if there was white showing on the inside of the oil cap. I haven't had the oil changed. The engine coolant is pink, I haven't used any antifreeze yet this year. Has the coolant level dropped any further? If not then I wouldn't worry about the head gasket, Just ensure the windscreen washer jets are sealed under the bonnet using silicone sealant, same advice to all 1.6 petrol focus owners otherwise water drips in to the engine which isint cool 1 Quote Link to comment Share on other sites More sharing options...
