help very appriciated
HELP please,
Started by -Richard-, Jan 25 2009 12:14 AM
5 replies to this topic
#1
Posted 25 January 2009 - 12:14 AM
hello new on here, my dads got a 1.6 16v fiesta ghia 05 plate 9.000 miles on clock
any way its doors are dilling with water as i notices a sloshing noice when i drove it and i have sourced the problem due to the door filling with water when it rains,
#2
Posted 25 January 2009 - 01:14 AM
bump up
#3
Posted 25 January 2009 - 05:04 AM
Im no mechanic but im sure you could just drill a hole in the bottom of the door, let it drain and then patch the hole with filler and give it a rub down, not like its gna be seen and if ur fussy buy a tin of paint and touch it up.
As for stopping it happening have you checked all the rubbers and seals?
#4
Posted 25 January 2009 - 08:38 AM
there should be drain holes in the bottom of the door, look to see if they are blocked.
#5
Posted 26 January 2009 - 09:41 AM
its nothing to worry about . mine does it aswell
when you open your door it should drain out of the bottom
just make sure it does otherwise you will end up with a bad rust problem
Regards
Woody
Regards
Woody
#6
Posted 26 January 2009 - 01:06 PM
Get a gun and shoot a hole out for the water to run through... Worked on Top Gear!
Latest Comments
More
