jeebowhite Posted July 23, 2014 Share Posted July 23, 2014 dont forget you will also need the chip coding. Quote Link to comment Share on other sites More sharing options...
mrgrumpy88 Posted July 23, 2014 Share Posted July 23, 2014 Yeah hoping to find some one to do that cheap enough. Sent from my GT-P3110 using Ford OC mobile app Quote Link to comment Share on other sites More sharing options...
jeebowhite Posted July 23, 2014 Share Posted July 23, 2014 to be honest, if you go to a street locksmith like I did, they just encoded and fitted a glass chip into my key. Much cheaper - £35 for that, or it was something like £90 for a locksmith to code the carbon key... Quote Link to comment Share on other sites More sharing options...
Guest Posted July 23, 2014 Share Posted July 23, 2014 Well I've just found a key cutters in Romford, Essex that will cut a new blade for £10 that with a new key it can all be done under £40 Quote Link to comment Share on other sites More sharing options...
mrgrumpy88 Posted July 23, 2014 Share Posted July 23, 2014 Yeah I had a flip conversion key cut for £6 had my origanl key board and that in it but would not work even tried reprogramming. Put it all back in my original non flip and it worked straight away no programming. Sent from my GT-P3110 using Ford OC mobile app Quote Link to comment Share on other sites More sharing options...
jeebowhite Posted July 24, 2014 Share Posted July 24, 2014 Did you definately take the immobiliser chip over? The chip is much more hidden on the key and is seperate to the circuit board, so you might find that is why it didnt work? Quote Link to comment Share on other sites More sharing options...
mrgrumpy88 Posted July 24, 2014 Share Posted July 24, 2014 Yeah swapped all bits over. Opened the door with key and started car but could not programme key for remote locking but worked fine when but all bits in original key. Sent from my GT-P3110 using Ford OC mobile app Quote Link to comment Share on other sites More sharing options...
jeebowhite Posted July 24, 2014 Share Posted July 24, 2014 very perculiar! programming the central locking can be tricky, but if you take the same transmitter over, I dont understand why it wouldnt work! Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted July 24, 2014 Share Posted July 24, 2014 Did you transfer over the battery contacts? Sent from my SM-G900F using Ford OC mobile app Quote Link to comment Share on other sites More sharing options...
mrgrumpy88 Posted July 24, 2014 Share Posted July 24, 2014 Yeah transferd all of my key insides. Just didnt get it was playing with it for ages. Sent from my GT-P3110 using Ford OC mobile app Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted July 24, 2014 Share Posted July 24, 2014 Either the battery wasn't making contact or the buttons weren't lining up properly. Sent from my SM-G900F using Ford OC mobile app Quote Link to comment Share on other sites More sharing options...
mrgrumpy88 Posted July 24, 2014 Share Posted July 24, 2014 Yeah I just gave up on it in the end. Will just get a second hand key and sort that one. Sent from my GT-P3110 using Ford OC mobile app Quote Link to comment Share on other sites More sharing options...
