Poor revving
cswagon
 Share
Hello
I have just bought a 1998 Ka and when it warms up it ticks over very poorly.It can range from approx. 800 rpm and then drop to almost a stalling speed.Any help will be very gratefully received thank you.
Graham.
Link to comment
check the petrol filter m8 change it.
it's locted on the near side at the rear under the car
looks like a drinks can
it mabe that your need to change the air filter aswell as it sounds like
it's getting starved of petrol or air ?
try running it without the air filter in place to see if it's that
or there may be a blockage or a crease in the petrol line nr the engine bayalso it's worth changing the spark plugs as that will cause it
there are so many items i can list for you to check but start with air filter & plugs & then let us know m8
keep us posted on your progress
Link to comment
Hello
I read somewhere else that the "idler valve " can cause similar symptons, is this a possibility?
If so, what needs to be done to this please?
I see a new one is only around twenty quid on E-Bay.
Graham.
Link to comment
  Only 75 emoji are allowed.
 Share
  • Create New...
Forums
News
Membership
