OllyTheGardener Posted September 20, 2012 Share Posted September 20, 2012 Hi all, I hope someone can help me with this. We have an 09 Fiesta Titanium, and recently the Bluetooth/voice/usb module stopped working. I managed to get hold of a second hand module, but I notice that the usb plug in the new module is of the mini usb type, whereas the plug in the old module looked more like a narrow usb A. My question is, is there an adapter available that will enable the older 09 usb cable in the car to plug into the mini usb of the new module? To me, it seems crazy that there wouldn't be, but not knowing the name of the type of connector in the car, searching the internet is like looking for a needle in a haystack! I just know that one end needs to have a male mini usb. Thanks in advance. Quote Link to comment Share on other sites More sharing options...
021C Posted September 21, 2012 Share Posted September 21, 2012 Hi, Your old USB BT module would have had part no 8M5T-19C112-AM? (i have this part ready to retro fit into my 08 Focus) The replacement module should have the same part number but the last two letters at the end will be different (indicating the newer revision) - 8M5T-19C112-AR (AS) etc. After the '-AM' version they introduced the mini USB connector. You should find that the cable used to connect to the module to the USB socket by the gear stick will be in two parts like the focus? or if not a single cable. Check out the thread and more specifically the post by iNath below in which he supplies (what I think) is the part number for the cable. 1710952 http://www.fordownersclub.com/forums/topic/28485-retro-fit-usb-it-works/#entry153715 I would suggest contacting your contact your local parts supplier and give them the part number of the newer module to be 100%. Trevor Porter at www.fordpartsuk.com will be able to help. Use their contact form and they'll come back to you will a suitable part. Stu Quote Link to comment Share on other sites More sharing options...
OllyTheGardener Posted September 25, 2012 Author Share Posted September 25, 2012 Thanks for the reply. The old module is 'AL' and the new one is 'AT'. I was hoping not to have to do any rewiring, but if needs must... The sockets by the gearstick are a usb and a 3.5mm aux. I was hoping I'd be able to use an off the shelf mini usb cable, run it from the module into the glovebox and plug the Ipod in there. But am I right in thinking the sound from the Ipod goes through the aux? Thanks again. Quote Link to comment Share on other sites More sharing options...
iNath Posted September 25, 2012 Share Posted September 25, 2012 With the module that has the mini-USB connection type your choice is to buy the cable from Ford (£52.86 as it comes with all the bluetooth wiring loom attached to it and has to be cut away) or buy a USB 2.0 A Female to B Male Mini 5Pin Converter Cable [like this one when they're back in stock, usually £1.10] but it will not fit in the fascia panel by the gearstick so you'll need to leave it hanging in the glovebox or find a better solution of integrating it. But am I right in thinking the sound from the Ipod goes through the aux? No, since the April 2012 USB update (see thread in guides section) the Ford 'Y' cable is redundant and iPod music plays purely through USB so you can use the official Apple cable that comes with it (or any other compatible cable) Quote Link to comment Share on other sites More sharing options...
OllyTheGardener Posted September 26, 2012 Author Share Posted September 26, 2012 so, if I were to get this http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=290754346627#ht_2275wt_1271 and this http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=280880133758#ht_2433wt_1271, then update the module with a pen drive, I'd be able to play the ipod without having to plug anything into the aux socket? Quote Link to comment Share on other sites More sharing options...
iNath Posted September 26, 2012 Share Posted September 26, 2012 so, if I were to get this http://cgi.ebay.co.u...#ht_2275wt_1271 and this http://cgi.ebay.co.u...#ht_2433wt_1271, then update the module with a pen drive, I'd be able to play the ipod without having to plug anything into the aux socket? Whilst I cannot say for certain, I believe that should work (it's a £2.18 gamble with good odds ;)) but you would need the iPod tucked away in the glovebox or find some way of attaching the female USB end to the existing fascia by the gearstick. Quote Link to comment Share on other sites More sharing options...
OllyTheGardener Posted September 26, 2012 Author Share Posted September 26, 2012 It's got to be worth a try! Looking at it, running a cable over the back of the glovebox and down to the module should be a piece of cake. I also prefer the idea of the Ipod being tucked well out of view, rather than on full show beside the handbrake! Thanks for the help. I'll order the parts and keep you informed. Quote Link to comment Share on other sites More sharing options...
irononreverse Posted October 8, 2012 Share Posted October 8, 2012 How did it go? Do you still have the old connector? Quote Link to comment Share on other sites More sharing options...
OllyTheGardener Posted October 18, 2012 Author Share Posted October 18, 2012 It worked! The usb connection is now in the glovebox, and the iPod stays out of site and out of the way. Thanks for everyone's help. Quote Link to comment Share on other sites More sharing options...
