Engine Sounding A Bit Rough
#16
Posted 22 February 2013 - 07:45 PM
Ive looked at a guide for replacing them. Could i do much damage if i mess anything up doing this?.
Any words of wisdom to remove them?.
http://www.ifixit.co...rk Plugs/5124/1
Thats the guide ive looked at.
#17
Posted 22 February 2013 - 07:51 PM
Removing them should be quite easy, just don't stick a 3ft pole on the ratchet if they are a bit tight. As they will snap
Refitting them, apply a little copper grease to the threads - makes them easier to remove in the future. Also screw them in by hand using the plug socket until they go all the way in. Be very careful not to cross thread the head is it will be a very expensive mistake.
#18
Posted 22 February 2013 - 09:11 PM
1 last thing to try and pick your brains about.
When i start the engine sometimes, mainly when its cold but does do it other times, on the rev counter, petrol, temp and speed gauges, the needles will flicker and a ticking noise will come from the gauges for a few seconds and then they will go into place as normal. Could this be an indication of something on its way im out ?
Thats id you know could be lots of reasons though im guessing. Thanks
#19
Posted 22 February 2013 - 09:32 PM
Ok thanks.
Im not sure about that one mate, never heard of it happening.
I would suggest you start a seperate thread to see if anyone can help you out.
#20
Posted 24 February 2013 - 11:29 AM
So yesterday i an oil and oil filter change. Spark plugs and air filter.
The engine sounds the same. A mechanic took a look and said its nothing to worry about but its not that im worried but the noise is just annoying.
The engine sounds like its tapping loudly when idle. Theres a few youtube videos of people with similar noises.
Anyone know what it may be?
#21
Posted 24 February 2013 - 08:33 PM
#22
Posted 25 February 2013 - 07:26 AM
The needles hesitate like they want to move so tgey flicker back and forth quicky and thats when the noise is. Its only when i start the car. If the engine is off and i just turn the mey they are fine, then i start the engine and thats when it happens. When it does happen though it also resets the MPG and miles to next refill, but doesn't reset the trip odometer which is strange :/
