kinghogg
Gears Jamming When Trying To Change
hi
i have a 2005 c max focus 1.6 petrol, my car has a intermitten problem with the gears sometimes the gear lever jams when it is in gear, and it can not be move to another gear, if you use a bit of force it can be move out of the gear then it is ok, you then can change gears with no problem.
agreed with above but also when was its last gearbox oil change.....
