Front Fog Light Problem On Fiesta 2011
fiesta0007
Dear friends
My ford fiesta 2011 front fog lights are not working..
do you think the problem was with fuse>?
so can you tell me location of fuse?
and how do i resolve this?
your kind response highly appriciately
thankx and regards
Dear friends
thankx and regards
Most likely a fuse,
Have you had them switched on before?
With the engine running
I don't have a fiesta or Id tell you the fuse location,
Buut check the manual for fuse location.
Most likely a fuse,
thank any way
Check fuse ( find location in manual ) it could be the relay to the fog lights fog light switch or a broken wire try the easiest first ( fuse ) then I'm afraid it's a matter of methodically fault finding . If you can get to the fog lights with a multi meter to see if you have power to them then work back from there , hopefully its something simple like a fuse
Remember they only work when the main lights are switched on...
Run the engine, and put the sidelights on. Then try the fog lights with the sidelights on. Failing that try the fog lights with the engine running and the headlights switched on.
can any 1 tell me location of front fog light fuse?
is necessary to start the engine or disconnect the battery
please help me guys ,
any electrician please
It's fuse number 23 in your engine bay fuse box, see if that's blown. If not try relay number 10, otherwise it's a broken wire or switch. check what potter18 said with voltage at the bulb's then work backwards.
guys
problem solved
thanks for ur valuable commnets
thankx u very much friends
