kurtangle01 Posted January 3, 2014 Share Posted January 3, 2014 Hi I've got a mk1 focus st170 and the seatbelt warning on the dash and chime is off have checked the obvious fuse which is gone but looking there's a way to turn it back on think the old owner put it off any help greatly appreciated Quote Link to comment Share on other sites More sharing options...
jeebowhite Posted January 3, 2014 Share Posted January 3, 2014 Is this the early MK2 or the late MK1.5 model of Focus? Preparation:1. Apply the parking brake.2. Select neutral3. Turn the ignition switch to the 0 position.4. Close all the vehicle doors from the inside of the vehicle.5. Unbuckle the drivers safety belt.Deactivating/Activating:1. Turn the ignition switch to position II. (Do not start the engine).2. The airbag warning indicator will extinguish within 10 seconds.3. NOTE: Step 3 must be completed within 60 seconds or the procedure must be repeated.Buckle then unbuckle the safety belt nine times, ending with the safety belt unbuckled.4. The safety belt warning indicator flashes three times to confirm the belt minder status change.5. To activate the belt minder, repeat Steps 1 through 3.6. After confirmation, the deactivation/activation procedure is complete. Quote Link to comment Share on other sites More sharing options...
