annaandmike Posted February 3, 2014 Share Posted February 3, 2014 I have lost my dashboard light along with the heater dial lights and the clock light in all all my internal lights I am thinking fuse any ideas Mike Mondeo 1.8 1997 year hachback Quote Link to comment Share on other sites More sharing options...
jeebowhite Posted February 4, 2014 Share Posted February 4, 2014 could be an internal fuse. check the fuse diagram for the internals and check them all over. Quote Link to comment Share on other sites More sharing options...
annaandmike Posted February 4, 2014 Author Share Posted February 4, 2014 Thank u I did pull out a socket from behind the right hand side were the light switch is can only think it's for a dimmer switch for dash board if this was disconnected could that turn them off ? Quote Link to comment Share on other sites More sharing options...
jeebowhite Posted February 5, 2014 Share Posted February 5, 2014 Its possible yes, as the resistor would close the circuit. If you have opened it there is the risk that this could be the cause. Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted February 5, 2014 Share Posted February 5, 2014 Definitely check the light switch is connected properly. That being disconnected or loose would most certainly kill your internal lights. Quote Link to comment Share on other sites More sharing options...
