ChrisCooper Posted February 4, 2014 Share Posted February 4, 2014 Is it normal to get a lot of splatter from the wiper nozzles after spraying? I find when I spray, I'll often have to wipe a few times manually to clear the streak going past the drivers wiper that's coming from the left nozzle, and also my bonnet gets a lot of residue around the nozzles from the fluid drying on. Last time I opened the bonnet too I had a lot of fluid going into the drainage channel out of the nozzles (not long sprayed the window before). I've heard about leaks from them, but there doesn't seem to be any signs of this (no fluid dripping from under the insulation on the bonnet top). Quote Link to comment Share on other sites More sharing options...
jeebowhite Posted February 6, 2014 Share Posted February 6, 2014 That is pretty normal to be fair, if your streaking across the windscreen then you might need to clear the grease off the windscreen, and the Wiper Blades, then perhaps may need to replace the Wiper Blades if they are past it! Quote Link to comment Share on other sites More sharing options...
ChrisCooper Posted February 6, 2014 Author Share Posted February 6, 2014 The streak isn't from the wipers, it's washer fluid continuing to leak out after spraying, collecting behind the wiper and then leaking past the end of it. Noticed it only does it some times though. Also, from looking at other threads it does seem to be a common problem, but none return valves are helping, so might give that a try when the weather gets warmer. Quote Link to comment Share on other sites More sharing options...
jeebowhite Posted February 6, 2014 Share Posted February 6, 2014 aaah perhaps I misunderstood! if only the mist jets weren't ridiculously overpriced... Quote Link to comment Share on other sites More sharing options...
alkyz89 Posted February 6, 2014 Share Posted February 6, 2014 Yea it's a common problem... I've also fitted 3 non return valves which haven't solved the problem Quote Link to comment Share on other sites More sharing options...
karlos1987 Posted February 6, 2014 Share Posted February 6, 2014 Does any one know where you can purchase the mist washer jets for a mk2.5 focus? Ford focus mk2.5 1.6 titanium. Quote Link to comment Share on other sites More sharing options...
Turvey Posted February 6, 2014 Share Posted February 6, 2014 Does any one know where you can purchase the mist washer jets for a mk2.5 focus? Ford focus mk2.5 1.6 titanium. eBay ;) Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted February 7, 2014 Share Posted February 7, 2014 eBay ;) But not through Allen Ford as they stitched up some members here by cancelling orders and upping the price to stupid levels. Quote Link to comment Share on other sites More sharing options...
karlos1987 Posted February 7, 2014 Share Posted February 7, 2014 Thanks. Ok ill make sure I don't go to Allen Ford. Cheers for the heads up. Ford focus mk2.5 1.6 titanium. Quote Link to comment Share on other sites More sharing options...
jeebowhite Posted February 7, 2014 Share Posted February 7, 2014 Bar stewards! I wont be using them ever again! but yeah they are crazy price sadly, £18 a jet is rediculous. if you dont want the heated variety though, I have heard that the Citroen Xsara Picasso mist jets are a straight swap... 1 Quote Link to comment Share on other sites More sharing options...
karlos1987 Posted February 7, 2014 Share Posted February 7, 2014 Would it really matter if I didn't get the heated ones? Ford focus mk2.5 1.6 titanium. Quote Link to comment Share on other sites More sharing options...
jeebowhite Posted February 7, 2014 Share Posted February 7, 2014 It wouldnt make the greatest of difference to be honest. You think about winter when the pipes are frozen only the jets get warmed up but it makes no real odds as far as I can see. Its what I am tempted to do. Quote Link to comment Share on other sites More sharing options...
karlos1987 Posted February 7, 2014 Share Posted February 7, 2014 I think I might go down that route then. They are probably a lot cheaper aswel. Ford focus mk2.5 1.6 titanium. Quote Link to comment Share on other sites More sharing options...
ChrisCooper Posted February 7, 2014 Author Share Posted February 7, 2014 I've rarely known it cold enough for the washer jets to freeze up, as long as you use a sufficiently strong mixture of washer fluid that contains antifreeze. Even if they do, a few minutes with the engine running should be enough to unfreeze them, considering they sit right above it. Big price difference though, around £5 for a pair compared to £15 each. Even the genuine Ford ones are about £10 for a pair unheated, so about 1/3 of the price of heated. 1 Quote Link to comment Share on other sites More sharing options...
alz Posted February 7, 2014 Share Posted February 7, 2014 try here for misting jets could be what you are looking for. http://www.ebay.co.uk/itm/Ford-Focus-Mk1-and-MK2-Mist-Spray-Washer-Jets-Zetec-TDCI-RS-LX-98-09-ST225-/121256383910?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item1c3b7195a6#ht_368wt_946 1 Quote Link to comment Share on other sites More sharing options...
