anthony2014 Posted February 8, 2014 Share Posted February 8, 2014 Hi i i bought a ford focus 1.8 tdci estate in noverber 2013 it has 90k on it which is not bad millage for the age. So one month later i heard a hissing sound took it back to the dealer and they replaced the turbo pipe which seem to fix it. I now have a new problem let me just say its just had a new luk flywheel and clutch my problem is when i lift the clutch up the car feel like its juddering the revs are around 1200-1800 one iam out of 1st gear it runs smooth but then when i crusing on the motorway between 60mph and 75 some times the streering wheel will shake i dont know if its related or anything. Any help would be great Quote Link to comment Share on other sites More sharing options...
anthony2014 Posted February 10, 2014 Author Share Posted February 10, 2014 No replys ??? Sent from my GT-I9300 using Ford OC mobile app Quote Link to comment Share on other sites More sharing options...
jeebowhite Posted February 12, 2014 Share Posted February 12, 2014 vibration like that would indicate that you have a wheel balance / alignment issue so you should get that checked out. Did you replace with a single or a dual mass flywheel? as that could cause some vibrations also. Quote Link to comment Share on other sites More sharing options...
anthony2014 Posted February 12, 2014 Author Share Posted February 12, 2014 Duel both luk Sent from my GT-I9300 using Ford OC mobile app Quote Link to comment Share on other sites More sharing options...
IINexusII Posted February 13, 2014 Share Posted February 13, 2014 did you replace the clutch + slave too? sounds like the flywheel has been installed incorrectly and isnt balanced, also check if the driveshafts have been re-installed correctly as that can also cause shakes and as jeebo said get the alignment checked Quote Link to comment Share on other sites More sharing options...
