kevin clarke Posted May 3, 2014 Share Posted May 3, 2014 1.6, 2003, 52k miles Anyone got this problem? Difficult to select reverse in my garage (lot of noise and resistance) but easy if it's rolling backwards down driveway (luckily I live on a slope). Also easy when the car has been running for 1-2 mins (car not moving). What's going on? Btw, selecting the other gears is ok. Quote Link to comment Share on other sites More sharing options...
ben1191 Posted May 3, 2014 Share Posted May 3, 2014 Reverse gear runs on a different cable to forward gears.its likely stretched and needs re adjusting. Speaking from experience of a merc sprinter though and assuming it's the same/similar. Sent from my iPhone using Ford OC Quote Link to comment Share on other sites More sharing options...
mgaking Posted May 3, 2014 Share Posted May 3, 2014 Reverse gear runs on a different cable to forward gears.its likely stretched and needs re adjusting. Speaking from experience of a merc sprinter though and assuming it's the same/similar. Sent from my iPhone using Ford OC Don't think this is correct for Fords. The cables can be adjusted but if all other gears are OK then probably not this. Reverse gear has always been a bit iffy on my 51 focus and on my current Fiesta bit no noises. Quote Link to comment Share on other sites More sharing options...
kevin clarke Posted May 5, 2014 Author Share Posted May 5, 2014 Great if it had a separate cable but agreed fairly sure it hasn't. So .... any ideas what's causing the problem selecting reverse gear? BTW, if I wait 2 mins in the garage or driveway then doesn't improve so why does driving for 2 mins make it easy (as normal)! Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted May 5, 2014 Share Posted May 5, 2014 Try pumping the clutch pedal a couple of times before engaging reverse for the first time. Sent from my SM-G900F Quote Link to comment Share on other sites More sharing options...
ben1191 Posted May 5, 2014 Share Posted May 5, 2014 Great if it had a separate cable but agreed fairly sure it hasn't. So .... any ideas what's causing the problem selecting reverse gear? BTW, if I wait 2 mins in the garage or driveway then doesn't improve so why does driving for 2 mins make it easy (as normal)! Yeah was pretty much a guess,I've never even looked at the box in the focus. Sent from my iPhone using Ford OC Quote Link to comment Share on other sites More sharing options...
flying clutchman Posted May 5, 2014 Share Posted May 5, 2014 Your clutch is dragging slightly. It's probably sticking on the spline slightly when cold. You might find it goes in better if you put it in 1st, keep the clutch down then go into reverse. There's definitely only 2 cables by the way! Quote Link to comment Share on other sites More sharing options...
RAIDER32 Posted May 5, 2014 Share Posted May 5, 2014 Great if it had a separate cable but agreed fairly sure it hasn't. So .... any ideas what's causing the problem selecting reverse gear? BTW, if I wait 2 mins in the garage or driveway then doesn't improve so why does driving for 2 mins make it easy (as normal)! I'm no expert on cars, but I had a little trouble with works Peugeot Boxer van once, I couldn't select reverse and I was blocking a one way bus lane in Chesterfield for about 5 minutes, at one point I had the handbrake on and in first gear and the clutch bit a little,from then it did actually let me select reverse. I repeated it again another time when the gears were a bit off. Also the other week I got my car back from garage after MOT/Service and the gears were not selecting very smoothly at all, before I left work last week I left handbrake on and while in first gear I just let the clutch bite slowly just putting a little pressure on, driving around today the gears were spot on. So might be worth a shot, just wouldn't do it in the garage! Handbrake on and just let the clutch bite, might straighten it out a bit. Quote Link to comment Share on other sites More sharing options...
Invisible Man Posted May 7, 2014 Share Posted May 7, 2014 My 2010 1.8 petrol has problems going into reverse. Sometimes I have to force it into reverse, but not very often. Or I let the clutch out slightly and it goes in no worries. It crunches if I try to reverse without it being properly engaged Quote Link to comment Share on other sites More sharing options...
ben1191 Posted May 7, 2014 Share Posted May 7, 2014 My 2010 1.8 petrol has problems going into reverse. Sometimes I have to force it into reverse, but not very often. I've always had to force my gear into reverse,I kept telling it to go into reverse but it wouldn't do it :D Sent from my iPhone using Ford OC Quote Link to comment Share on other sites More sharing options...
