mudman Posted March 27, 2015 Share Posted March 27, 2015 I've gutted the dpf as the !Removed! was the culprit for killing my turbo, I've done 100 miles or so sins the overhaul without having the ecu remapped with no problems at all an it's great to see my average mpg go up an up, I was under the impression the car will go in to limp mode when the dpf is removed should it an will it ? Quote Link to comment Share on other sites More sharing options...
IINexusII Posted March 27, 2015 Share Posted March 27, 2015 i think you need to remap to remove the DPF regeneration from the ECU, it will still attempt to regenerate thinking the DPF internals are there Quote Link to comment Share on other sites More sharing options...
mudman Posted March 27, 2015 Author Share Posted March 27, 2015 But wouldn't it only regen when it feels pressure / dpf clogging up ? Quote Link to comment Share on other sites More sharing options...
TomsFocus Posted March 27, 2015 Share Posted March 27, 2015 That's interesting, it should be throwing a fault code at least. Have you only driven it gently so far or given it some stick? Also no, it should regen every ~500 miles as a failsafe regardless of pressure. Quote Link to comment Share on other sites More sharing options...
artscot79 Posted March 27, 2015 Share Posted March 27, 2015 From what I understand it wont throw a code till it tries to regen then you'll get the problems hence why they reprogramme the ecu to bypass the regen process and remove the eloys top up fault its not as simple as gut it and everything will be fine Quote Link to comment Share on other sites More sharing options...
mudman Posted March 27, 2015 Author Share Posted March 27, 2015 Ive put my foot down a couple of times but Mainly gently driving an went on the motorway last night only a couple of junctions Quote Link to comment Share on other sites More sharing options...
TomsFocus Posted March 27, 2015 Share Posted March 27, 2015 Ok, fair. It should have thrown a code when it sees 0kPa pressure difference under load but it might be a 'silent' fault (no EML). Arthur may well be correct that you only start seeing problems when it attempts a regen, not sure. Quote Link to comment Share on other sites More sharing options...
