Jones93 Posted April 13, 2015 Share Posted April 13, 2015 Hello I have just bought my zetec s this weekend and unfortunately my auxiliary belt is now around 2mm thick :/ I was wondering if anyone could give me a heads up or if they have any haynes style instructions,this would be brilliant. It is the front belt ie, around alternator and the water pump and another pulley. Any advice? Is the 1.6 engine the same as in the focus? Many thanks Steve Quote Link to comment Share on other sites More sharing options...
iantt Posted April 13, 2015 Share Posted April 13, 2015 petrol or diesel Quote Link to comment Share on other sites More sharing options...
Jones93 Posted April 13, 2015 Author Share Posted April 13, 2015 Sorry 1.6 petrol 57 reg Quote Link to comment Share on other sites More sharing options...
iantt Posted April 13, 2015 Share Posted April 13, 2015 ah, right they are stretchy belts, have you got air con, 2 belts if you have..old belts you just cut off, new belt you have to wind on normally with special tools that make fitting easier. you can get them on without tools but potentailly you can damage new belt putting it on Quote Link to comment Share on other sites More sharing options...
Jones93 Posted April 13, 2015 Author Share Posted April 13, 2015 http://www.eurocarparts.com/ecp/c/Ford_Fiesta_1.6_2007/p/car-parts/engine-parts/belts-chains-and-tensioners/car-drive-belt/?202777435&1&22a8662c66945375a40bfe113f0c0ad9bddc4f6f&000108 The diagram of the belts is one there and that is the belt I have bought, am I best of getting the two belts kit? and yes it has Ac thanks Quote Link to comment Share on other sites More sharing options...
iantt Posted April 13, 2015 Share Posted April 13, 2015 yep, that loks like them, 2 belts required unless your just replacing the outer ps belt, inner one requires the outer one cut off Quote Link to comment Share on other sites More sharing options...
iantt Posted April 13, 2015 Share Posted April 13, 2015 if you see the other more expensive belts you will see the special tools are included Quote Link to comment Share on other sites More sharing options...
Jones93 Posted April 13, 2015 Author Share Posted April 13, 2015 Its the inner longer one that needs replacing, the kit it is then! Do you know of any guides to make the installation clearer eg which is the tensioner etc? or is it as simple as cut the old ones of and stretch the other two over? and thanks for your help I appreciate it mate Quote Link to comment Share on other sites More sharing options...
iantt Posted April 13, 2015 Share Posted April 13, 2015 there is no tensioner, thats what stretchy belts replace, the tools help the belt over the crank pulley without damaging new belt ribs Quote Link to comment Share on other sites More sharing options...
Jones93 Posted April 13, 2015 Author Share Posted April 13, 2015 Thank you very much for your help, just to confirm its a straight swap, just use the tools provided to stretch over the pulleys no other tools needed? Quote Link to comment Share on other sites More sharing options...
iantt Posted April 13, 2015 Share Posted April 13, 2015 nope, thats it ,apart from a spanner on the crank pulley bolt to turn pulley as you fit belt,with the kit with tools i would have thought you get instructions, know the ford belt kit did do, ford kit is about £32 Quote Link to comment Share on other sites More sharing options...
