B4K3R Posted December 1, 2015 Share Posted December 1, 2015 Hello is there a link to what you can do with a mod elm327 for a mk3 focus couldn't find anything in posts thanks Quote Link to comment Share on other sites More sharing options...
JW1982 Posted December 1, 2015 Share Posted December 1, 2015 On the MK3 all configuration settings of the Central Car Configuration (CCC) can be changed with an ELM327 interface and the free FoCCCus software.. The Central configuration is stored into the BCM (main configuration) and the instrument cluster (backup). Basically every singe option of the car is configured by the CCC. By changing the CCC settings you can activate/deactivate functions of the car. For example: * Cruise Control (after retrofitting the switches). * Hill Start Assist. * DDS Tyre Deflation Warning System. * Start/Stop deactivation. * Configuration of the wheel/tyre size. Next to this it is also possible to update the software of a limited number of (CANbus) modules. However you should only do this if you have the skills and knowledge. This is a very powerful function which can easily brick a module if something goes wrong. 1 Quote Link to comment Share on other sites More sharing options...
B4K3R Posted December 1, 2015 Author Share Posted December 1, 2015 Thanks is there a complete list of what you can activate in the ccc and I won't touch the canbus 馃槉 1 Quote Link to comment Share on other sites More sharing options...
JW1982 Posted December 1, 2015 Share Posted December 1, 2015 Put your VIN number on the website below and the website will show all CCC settings of your car based on AS-BUILT data from the ETIS database. http://ford.xtlt.ru/ab/ 1 Quote Link to comment Share on other sites More sharing options...
B4K3R Posted December 2, 2015 Author Share Posted December 2, 2015 Thanks again does anyone on here sell them already modified Quote Link to comment Share on other sites More sharing options...
B4K3R Posted December 4, 2015 Author Share Posted December 4, 2015 Anyone in the Birmingham area willing to do it for 拢拢 Quote Link to comment Share on other sites More sharing options...
iantt Posted December 4, 2015 Share Posted December 4, 2015 Just buy one off eBay and diy Quote Link to comment Share on other sites More sharing options...
B4K3R Posted December 4, 2015 Author Share Posted December 4, 2015 Can they be trusted heard there's some dodgy ones Quote Link to comment Share on other sites More sharing options...
iantt Posted December 4, 2015 Share Posted December 4, 2015 i bought one, no problems Quote Link to comment Share on other sites More sharing options...
Dee_82 Posted December 5, 2015 Share Posted December 5, 2015 http://www.spanglefish.com/TunnelratElectronics/ I recommend these guys 1 Quote Link to comment Share on other sites More sharing options...
B4K3R Posted December 5, 2015 Author Share Posted December 5, 2015 Thanks which software for mk3 ff2 ELMFFN, Elmconfig, Focccus and Forscan Quote Link to comment Share on other sites More sharing options...
JW1982 Posted December 5, 2015 Share Posted December 5, 2015 On the Focus MK3 you can only use FoCCCus and Forscan. The other programs you mentioned do only work on other/older Ford models. The FoCCCus software can be used to read/configure the Central Car Configuration, show the hardware/software versions of most CANbus modules and (not recommended) update the software of some CANbus modules. The Forscan software can be used for diagnostics. This program can read/erase most DTC codes from most CANbus modules. Note that despite the fact that the Forscan software is developed specifically for Ford it will not show all Ford specific DTC codes. Some Ford specific DTC codes can only be shown with the Ford IDS system. Next to a decent ELM3287 interface and the FoCom diagnostic system I also own the Ford IDS system. The Ford IDS system shows several DTC codes that are not shown by the Forscan software or Ford specific FoCom diagnostic system. Quote Link to comment Share on other sites More sharing options...
B4K3R Posted December 5, 2015 Author Share Posted December 5, 2015 Thanks all Quote Link to comment Share on other sites More sharing options...
