ZetecShearer1987 Posted February 7, 2016 Share Posted February 7, 2016 Hi all I'm looking to do a full clean on my car today with a clay polish and wax, if the weather holds up. My question is that on the roof of my focus where the plastic trims run from the back to the front where the water drains, there is moss and green crap caught under the strips that i want to shift off the paintwork. Whats the best way to tackle this. Will using a brush scratch the paintwork, or is there a better tip to do this Quote Link to comment Share on other sites More sharing options...
TomsFocus Posted February 7, 2016 Share Posted February 7, 2016 Pressure washer. You can use a brush, but depends on type, a proper detailing brush is fine...a stiff wheel brush or similar will probably cause light scratches. Quote Link to comment Share on other sites More sharing options...
GMX Posted February 7, 2016 Share Posted February 7, 2016 A garden hose on the "single jet" setting on the nozzle will do it, if you haven't got access to a pressure washer. I've had several cars that have concealed gutters/trim beneath the actual roof rails, that during the winter gain pine needles, mossy and lichen bits and general crud. Putting the hose nozzle as close as you can to the slit at an angle of about 30° and pulling the trigger, shifts the the lot and propels out of the channel. If you do it on both channels, from the front and from the back, you'll ensure nothing was left behind. To avoid a comedy moment, the nozzle needs to be angled, otherwise you'll get a face full as the water blows back. Quote Link to comment Share on other sites More sharing options...
ZetecShearer1987 Posted February 7, 2016 Author Share Posted February 7, 2016 Thanks for the responses, managed to wash the car today, think im gonna tackle the tough grime on the next wash. I need to clay the car asap too as white is a lovely colour but it shows up every blemish and mark known to man. Quote Link to comment Share on other sites More sharing options...
GingerFlame Posted February 7, 2016 Share Posted February 7, 2016 Use all purpose cleaner for the grime/plastics You need fallout remover for the paintwork clay clay lube/Quick detailer detailing brushes work wonders too www.yorkshiredetailing.co.uk - approved resellers of the Highest quality detailing & Valeting supplies Quote Link to comment Share on other sites More sharing options...
williamweb Posted February 7, 2016 Share Posted February 7, 2016 Surprising what you can achieve with a soft bristled toothbrush. Sent from my iPad using Ford OC Quote Link to comment Share on other sites More sharing options...
