kpg Posted May 26, 2016 Share Posted May 26, 2016 https://www.theretrofitsource.com/ they know their stuff, you can take a gamble and get some knock offs dirt cheap but its a bit of a mine field. I got a cheap set of ballasts and some cheapo bulbs, the bulbs were terrible, shoddy light pattern and nowhere near the 4300k they were supposed to be, so got some from TRS, much better quality but one of them flickers slightly, its the cheap ballast that's doing it so will need to replace them as well. They're a bit pricey for a whole kit. Projectors, bulbs, ballasts etc. Might try it out with a cheaper projector first maybe. Sent from the pub with a pint in the other hand. Quote Link to comment Share on other sites More sharing options...
Dee_82 Posted May 26, 2016 Share Posted May 26, 2016 if you want to cut corners id suggest the ballasts are a good place to start and could save you a fortune, you don't need the relay kit and if you do you can buy a cheap eBay one, I wont skimp on bulbs again though which just leave the projector, it is expensive but ask yourself how much you will have to spend if the cheap projectors turn out to be crap and you have to send them back Quote Link to comment Share on other sites More sharing options...
ScorpionSX Posted May 27, 2016 Share Posted May 27, 2016 Just a head's up, I think I read somewhere on this forum that when you switch to HIDs on MK3, you also need to bypass the vehicle's check for bad bulbs or something like that - it just needs a correction in the car software. Nothing that can't be done with Focccus I believe, and with the same ELM cable you used with the MK2s, but it can save you some nerves after you install the HID Kit. (as far as I remember, the lights will light up, but they will probably give you warning on the dash computer) Otherwise, I'm really looking forward to see what can be done with MK3s headlights, almost makes me want to switch to newer car, lol :D 1 Quote Link to comment Share on other sites More sharing options...
kpg Posted May 27, 2016 Share Posted May 27, 2016 I have HIDs h7r in my headlights at the minute and they give the bulb out message. I fixed it at one point with cancellers but after the PCM update it came back again. I'm too afraid to disconnected the battery now incase the update disappears lol Sent from the pub with a pint in the other hand. Quote Link to comment Share on other sites More sharing options...
mjt Posted May 27, 2016 Share Posted May 27, 2016 The software will be held in flash memory so won't disappear if the power is removed. 1 Quote Link to comment Share on other sites More sharing options...
ScorpionSX Posted May 27, 2016 Share Posted May 27, 2016 3 hours ago, kpg said: I have HIDs h7r in my headlights at the minute and they give the bulb out message. I fixed it at one point with cancellers but after the PCM update it came back again. I'm too afraid to disconnected the battery now incase the update disappears lol Sent from the pub with a pint in the other hand. Found the topic: You can read about the tweak JW1982 used to fix the warning message, looks pretty easy if you have an OBD cable... Quote Link to comment Share on other sites More sharing options...
kpg Posted May 27, 2016 Share Posted May 27, 2016 I have HIDs h7r in my headlights at the minute and they give the bulb out message. I fixed it at one point with cancellers but after the PCM update it came back again. I'm too afraid to disconnected the battery now incase the update disappears lol Sent from the pub with a pint in the other hand. Found the topic: You can read about the tweak JW1982 used to fix the warning message, looks pretty easy if you have an OBD cable... I've had a look at that before but couldn't see any specifics. Just mentions the use of the cable. Must have a look over it again. Thanks Sent from the pub with a pint in the other hand. Quote Link to comment Share on other sites More sharing options...
ScorpionSX Posted May 27, 2016 Share Posted May 27, 2016 Yeah, no exact step by step guide (maybe there's something more in the rest of the topic), but I believe it should be just a matter of settings in software like Focccus, or some other alternative for MK3s. Quote Link to comment Share on other sites More sharing options...
fugleman Posted May 27, 2016 Share Posted May 27, 2016 My first choice actually was the same lights as you have linked KPG but at the time no stock and $100 more than the ones i bought- that is a good price you should get them.Sales guy said they were of a better quality build but not sure if they are halogen or hid projectors? Ended up buying generic H1 Mini projectors and 5500k bulbs from http://www.vikom.com.au/product/generic-mini-h1-bi-xenon-projectors-2/ and T3C CANBUS ballasts from a local place-same as http://www.dhgate.com/store/product/2015-new-t3c-12v-35w-canbus-slim-ballast/248341367.html would have liked the morimoto mini H1 7.0 and xb35 ballasts and standalone canbus harness but was tight on cash at the time.Still very happy with generic projectors output and cutoff for $60.00 au-and very bright white bulbs!http://www.vikom.com.au/product/h1-vikom-vx35-hid/ (but beware the yeaky/morimoto style bulbs with the detachable power wiring hits the damn chassis bracing stupid design by ford-so you need to shorten them) see pic 1 Quote Link to comment Share on other sites More sharing options...
