Tim84 Posted September 1, 2016 Share Posted September 1, 2016 Hiya what issues has people had with this Sony system. Mine turns on but only says ford audio can't play cd or anything else the only thing that works is bluetooth but even then the music or phone does bugger all. Done hard reset and still doesn't work. Quote Link to comment Share on other sites More sharing options...
Russ Posted September 1, 2016 Share Posted September 1, 2016 Probably waiting for the 4 digit code to unlock it? Quote Link to comment Share on other sites More sharing options...
Joss max Posted September 2, 2016 Share Posted September 2, 2016 On 01/09/2016 at 5:45 AM, Tim84 said: Hiya what issues has people had with this Sony system. Mine turns on but only says ford audio can't play cd or anything else the only thing that works is Bluetooth but even then the music or phone does bugger all. Done hard reset and still doesn't work. Read here http://www.fordownersclub.com/forums/search/?type=all&q=radio+codes Quote Link to comment Share on other sites More sharing options...
shy_mocha Posted September 7, 2016 Share Posted September 7, 2016 My Sony system has swallowed a CD. Everything else works but it flashes up with 'CD Malfunction' and won't play or eject. Not a massive issue as I use USB or radio mostly but it niggles me that it isn't fully functioning. Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted September 7, 2016 Share Posted September 7, 2016 Is it a multidisc unit or single? Multidisc units are known for jammed mechanisms. Single units suffer from drive motor failures. If you dismantle the unit you may be able to extract any discs but can't guarantee the discs will survive or that the radio will be restored to perfect functionality. Sent from my SM-G930F Quote Link to comment Share on other sites More sharing options...
