Jonanstee Posted January 9, 2017 Share Posted January 9, 2017 I was going through my dash last night trying to decide what else needs painting when I came across these two sets of wires that don't go to anything. Does anyone know what they're for? 2 Quote Link to comment Share on other sites More sharing options...
dezwez Posted January 9, 2017 Share Posted January 9, 2017 I think Wiring for heated seats and passage air bag switch on or off not fitted on your car 2 Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted January 9, 2017 Share Posted January 9, 2017 From left to right it's usually PAB deactivation light, front demist, rear demist and ESP activation light if all functions fitted.On a CC model the far right one woukd be for the roof.Sent from my SM-G930F 1 Quote Link to comment Share on other sites More sharing options...
Jonanstee Posted January 9, 2017 Author Share Posted January 9, 2017 So if I could find the buttons to install would everything work just like that? Or is there more to it? 1 Quote Link to comment Share on other sites More sharing options...
Dee_82 Posted January 9, 2017 Share Posted January 9, 2017 I believe the ESP needs a little more than a button to get working, I don't think it has the correct connections, heated seats will require a load of extra work as would heated demist front and rear, i think the passenger airbag deactivation is straightforward though 1 Quote Link to comment Share on other sites More sharing options...
isetta Posted January 9, 2017 Share Posted January 9, 2017 they do this so they can use a common wiring loom and not make infinite number of different looms for each trim level/options. apart from other bits missing that have been mentioned there could also be relevant fuses and relays (the square plastic boxes that plug into the fusebox) missing. 1 Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted January 9, 2017 Share Posted January 9, 2017 An airbag deactivation system also requires the key switch in the glovebox and activation.Some Ford dealers will do this on signing a disclaimer but majority will refuse.I think it can be done with Forscan, ELM Config or Foccus software though.Sent from my SM-G930F 1 Quote Link to comment Share on other sites More sharing options...
Jonanstee Posted January 9, 2017 Author Share Posted January 9, 2017 So yeah.. I'm just going to leave it how it is 😂😂. What's your guys opinion on painting that bit though? Seen photos of it done but undecided if I want to do it or not 1 Quote Link to comment Share on other sites More sharing options...
mrmetallica Posted January 9, 2017 Share Posted January 9, 2017 i have installed esp .just a case of running wires from the switch to under the battery . ive also installed heated seats .just a case of running wires from under the seat to switch and wires from fuse box to the seat connector 1 Quote Link to comment Share on other sites More sharing options...
Jonanstee Posted January 9, 2017 Author Share Posted January 9, 2017 6 minutes ago, mrmetallica said: i have installed esp .just a case of running wires from the switch to under the battery . ive also installed heated seats .just a case of running wires from under the seat to switch and wires from fuse box to the seat connector I'm interested in the heated seats. Do you have any photos of where you had to run the wires? Quote Link to comment Share on other sites More sharing options...
mrmetallica Posted January 9, 2017 Share Posted January 9, 2017 Just now, Jonanstee said: I'm interested in the heated seats. Do you have any photos of where you had to run the wires? my focus is a 09 titanium . i could get some when the weather gets better Quote Link to comment Share on other sites More sharing options...
Jonanstee Posted January 9, 2017 Author Share Posted January 9, 2017 2 hours ago, mrmetallica said: my focus is a 09 titanium . i could get some when the weather gets better I have a 2006 lx. Going to assume because it's a lx there is a lot more that needs to be done than just running a wire? Quote Link to comment Share on other sites More sharing options...
mrmetallica Posted January 9, 2017 Share Posted January 9, 2017 23 hours ago, mrmetallica said: I have a 2006 lx. Going to assume because it's a lx there is a lot more that needs to be done than just running a wire? i would think so .have a look see if you have the plugs for the heated seats behind as in first post Quote Link to comment Share on other sites More sharing options...
