PaulBee14 Posted May 1, 2018 Share Posted May 1, 2018 Hi, I have recently purchased a 2014 S-Max, and discovered that the headlights are on as soon as the engine is started. The switch is in the off position, then the headlights go off when switched to sidelights (but sidelights don't come on), then headlights come on again when switched to headlights. If anyone has any suggestions as to whether this is normal, or how to fix it, I would really appreciate it! Thanks Quote Link to comment Share on other sites More sharing options...
blahde2 Posted October 28, 2018 Share Posted October 28, 2018 (edited) Do the daytime running lights (DRL) work? If not then the headlights could have been bodged so they come on instead. A dodgy MOT tester might accept that and pass the vehicle. Take it back to the vendor (if a dealer/trader) and ask them about it/to fix it. If they bodged a fault, or in fixing one introduced a writing issue, possibly from accident repair perhaps. They should be liable to fix it if it was sold with a fault/bin standard repair. Hope it's not an accident repair for your sake. It could be the headlight control switch or in the wiring going into the headlights themselves. If so, a good scrappy should have a replacement switch. Easy fix if so. Edited October 28, 2018 by blahde2 Typos Quote Link to comment Share on other sites More sharing options...
