Mk3 Prefacelift Sync 2 8" touchscreen upgrade, How to guide with pics!!!
1 hour ago, alexp999 said:
CD slot location varies by model regardless of Sync version.
The new Mk8 Fiesta the CD slot is optional and gets fitted in the glove box.
Ahh maybe that's what I'm thinking of then. I still want a US fascia!
And I've checked my firmware, looks like it's already on 3.10 and a long press of the voice button doesn't do anything. As it's an unofficial ware, I might try the 'update' to see if it will install 3.08...
  • Replies 1.4k
  • Views 400.3k
  • Luke_Anderson
    Luke_Anderson
    Cub and baba? And you think I’m the one that needs to grow up 😂 you see petal, the problem with people like you is that you expect things to be done for you, you don’t want to invest the time or effor
  • Nathan Buffery
    Nathan Buffery
    The easiest place to take the MS can is from the heater module. If I remember rightly it's the blue plug.  Pin 18 grey & orange on the heater module goes to pin 16 on the sync module.  P
  • Luke_Anderson
    Luke_Anderson
    Thanks! If anyone has any questions I’m more than happy to help!  It took me 10 hours to do but that was with some figuring out along the way, I reckon if I was to do it again I could do it in ha
Hmmm must be something else then as it should be working fine 🤔
What, even on 3.10?
Yeah it did I’m afraid 😕
Nuts.
Hm. Could you send me a screeny of your APIM as-built as it is now do you think? Maybe I could compare with mine and see if there's a bit different which is the cause...
Of course it could also be in the ccc which would take ages to compare...
To say I’m happy is an understatement! So I spotted a complete sync 3 system from a 2018 c-max from an eBay breaker, he clearly didn’t know what he had but I took a gamble and ran the plate through etis. Full of hope I opened my package today, full sync 3 navigation system with audio unit, apim, fcim, fascias, usb hub and loom for just £162 delivered! Lucky or what!!
16 minutes ago, Phil21185 said:
Nuts.
Does normal voice control work? If so I’d say it’s more a phone setting
Well now I'm just annoyed! Any chance of dropping that sellers ID??!
Nice one! So what was involved in getting it working and what is it like compared to sync 2?
Yeah normal voice control works. I guess I'll just have to have a fiddle about...
I only plugged it in to make sure it worked but it’s works apart, so much more responsive, I’ll let you know more once I get it installed and programmed at the weekend 👍🏻👍🏻
... and the only sets I can find are £600...
I got really lucky, like reallllly lucky 😂
Searching can be tedious but you have to search everything,
ford radio
ford stereo
ford headunit
ford breaking
etc etc
as long as it’s sync 3 it’ll fit, doesn’t matter if it’s from a focus, a mondeo or whatever. You only need the apim and screen and the hub
if you search regular you’ll find one at a sensible price 👍🏻
Thanks Luke, I'll keep my eyes open. Woo you got stickied!
Hurrah! All round to mine for a party? 😂
Ok but only so I can steal your shiny new sync 3 system 🙂
I’ll have a lovely sync 2 one you can knick 😂
I already have one of those... 🙂
I’ll keep an eye out for you mate 👍🏻👍🏻
Cheers. I've seen a screen only from a 2017 ranger for £300...
Also looks like android users are SOL when it comes to long-press access of Google now. Apparently later updates worked for siri eyes free but they didn't think to also make it work with Google.
Thats bit of a bugger, considering I'd just managed to update my sync 1 to enable it...
On 5/26/2018 at 9:10 PM, Luke_Anderson said:
TMC is live traffic updates, so when you use navigation it’ll alert you to traffic jams up ahead etc. ACM module is the audio unit ( the bit with the CD player slot ) on the back there are 2 black connectors, one is larger than the other, you remove the 2 wires from the larger one and insert them into the smaller one. This will then transmit the traffic updates to the screen.
Question!! So I've been finishing off the car today and along my travels I found that my ACM connector already has pins 6 and 19 taken in the smaller connector whilst pins 4 and 5 are missing in the larger connector, so I just wanna make sure its definitely meant to be from large ACM plug to the small ACM plug, not the other way around.
Another question!
the MS CAN connection, now you've listed them as Grey/Orange for pin 16 and Purple/Orange for pin 17... mine dont follow the same colours as you've listed or on the other sites you linked me to... dare I move them? :S
Being a facelift yours might be a bit more straight forward. I’d say the acm wiring is probably already there and maybe the ms can as well?
I’m all installed and programmed on sync 3 now! The difference is incredible, if you get the opportunity to get sync 3 over sync 2 then do it!
Ffs! I just got sync2 lol!
Grats on your conversion though! I'll have to keep my eyes open for a system. I've decided I want the hub too though...
