ajc1969 Posted February 7, 2010 Share Posted February 7, 2010 Cigar lighter (used for phone charger etc) stopped working. Traced (or so I thought) to a blown fuse, probably as a result of a piece of silver paper being pushed into the cigar lighter (kids)! Silver paper removed, fuse replaced but still no power. 12V boot socket also dead. WHat am I missing? Quote Link to comment Share on other sites More sharing options...
Richard G Posted February 7, 2010 Share Posted February 7, 2010 The two sockets are on different 20A cicuits Front is F39 that ought to be 2 from left in short top row of fuses in CJB and Rear is F79 that ought to be 8 from right in bootm row in CJB Quote Link to comment Share on other sites More sharing options...
ajc1969 Posted February 7, 2010 Author Share Posted February 7, 2010 Checked both of these and replaced the one that had blown but still both sokets are "dead", wondering if there is anything else that may link the two and has "blown" or if it is pure coincidence that the the two have failed at the same time, mind you still doesn't explain why the new fuse hasn't had the desired effect on the cigar lighter in the main cabin. Quote Link to comment Share on other sites More sharing options...
ajc1969 Posted February 8, 2010 Author Share Posted February 8, 2010 Had another look and figured that the contacts may be dirty or bent. Stupidly had ignition on so when I stuck the small screwdriver into the socket I shorted it (blue sparks) BUT fuses etc remained intact AND the socket started to work again. PRoblem now solved but quite how ... I don't really know! Quote Link to comment Share on other sites More sharing options...
