Cruise Control
Hi all,
Would anyone know if Ford can install Cruise Control after the factory? if so how much usually
I have a 2011, 1.25 Fiesta.
If you have this connection on your steering column you can do it yourself by adding the switch and programming with Fordscan. If you have less wires then it’s not wired up for CC and you’ll need additional switches/sensors and the loom. Ford will charge a fortune, if they do it at all.
Sorry where would i find that?
Open the two half’s if the steering column trim behind the steering wheel. I think it’s 2 or 3 Torx screws from underneath.
