Stuart35 Posted June 8, 2018 Share Posted June 8, 2018 Does the 2007 1.8 use a silver calcium battery? I have checked the manual, but it doesn't specify one is needed. Thanks. Quote Link to comment Share on other sites More sharing options...
YOG Posted June 8, 2018 Share Posted June 8, 2018 Petrol? Diesel? What battery is fitted at the moment? Quote Link to comment Share on other sites More sharing options...
Stuart35 Posted June 9, 2018 Author Share Posted June 9, 2018 Petrol. It has a GS LBN3 MF fitted. Quote Link to comment Share on other sites More sharing options...
YOG Posted June 9, 2018 Share Posted June 9, 2018 GS batteries are owned by Yuasa, so should be good: http://www.gs-battery.com/ Can't find the code that you supplied on their website, but, putting in 2007 1.8 petrol hatchback, it shows the correct battery code as SMF075 https://batterylookupgb.gs-battery.com/datasheet/download/pdf/sku/SMF075/ Additional info on their website re Ford batteries: http://www.partinfo.co.uk/files/Information regarding the use of Silver Calcium Batteries.pdf I would check the battery measurements of Length 242mm Width 175mm Height 175mm with your battery, and, if the same, you need an 075 battery. Some examples here at TAYNA: https://www.tayna.co.uk/car-batteries/types/075/ I've normally gone for the Varta, with a 5 year Guarantee: https://www.tayna.co.uk/car-batteries/varta/d21/ Quote Link to comment Share on other sites More sharing options...
