Smeig Posted January 5, 2022 Share Posted January 5, 2022 Merry Christmas everyone! 🎄 Dear Mr. Zico! I'm sorry, but I was late to download the files before the expiration date. Would you please re-up the 5.11 files? THANKS YOU! Sorry for my bad English. Quote Link to comment Share on other sites More sharing options...
Zico Posted January 8, 2022 Share Posted January 8, 2022 On 1/5/2022 at 11:56 AM, Smeig said: Merry Christmas everyone! 🎄 Dear Mr. Zico! I'm sorry, but I was late to download the files before the expiration date. Would you please re-up the 5.11 files? THANKS YOU! Sorry for my bad English. Hi @Smeig I will re-upload the file. Link https://files.fm/u/q8bgsjm76 - currently uploading but should be ready shortly. 1 Quote Link to comment Share on other sites More sharing options...
Smeig Posted January 9, 2022 Share Posted January 9, 2022 Dear Mr. Zico! Thank you very much! You helped me a lot! All the best to you! 1 Quote Link to comment Share on other sites More sharing options...
Robj221 Posted January 30, 2022 Share Posted January 30, 2022 Hello. What does 5.11 add and is the link above stop working. Thanks Quote Link to comment Share on other sites More sharing options...
Zico Posted January 31, 2022 Share Posted January 31, 2022 On 1/30/2022 at 4:12 PM, Robj221 said: Hello. What does 5.11 add and is the link above stop working. Thanks Link will still work until the 9/3/22 https://files.fm/u/q8bgsjm76 Ford don't publish the changes but it's likely to be bug fixes or compatibility fixes. There is always the saying, if it ain't broke, don't fix it. Quote Link to comment Share on other sites More sharing options...
Hugo Santini Posted February 12, 2022 Share Posted February 12, 2022 Hello! I´m from Argentina. I have a 2014 Ford Fiesta S Plus from Brazil. I have a problem with my aux mode. Everything is working fine with the radio, cd, "free hands", I can connect my cellphone with SYNC, and I can make calls without problems. But.... If I press AUX button, screen goes black and nothing happen. My cellphone is playing some music, but the screen still black and I can not see any option in the screen, can´t hear the music neither. If I try to install this update #5.11, will be a solution maybe? Sorry about my english ja! Regards. Hugo Quote Link to comment Share on other sites More sharing options...
Hugo Santini Posted February 12, 2022 Share Posted February 12, 2022 I attached a photo with my problem.. Hope you can help me. Thanks! Quote Link to comment Share on other sites More sharing options...
Hugo Santini Posted February 12, 2022 Share Posted February 12, 2022 My Sync module... Quote Link to comment Share on other sites More sharing options...
Hugo Santini Posted February 12, 2022 Share Posted February 12, 2022 Some more information. Maybe it can help... 😞 Quote Link to comment Share on other sites More sharing options...
Zico Posted February 13, 2022 Share Posted February 13, 2022 AUX mode is if you plug in an external device (ipod or other music device) and if you have nothing connected it won't show anything. Quote Link to comment Share on other sites More sharing options...
Hugo Santini Posted February 14, 2022 Share Posted February 14, 2022 Hi Zico, thanks for your response. A few months ago, when I press the AUX Button, I could see the AUX menu. Today, the screen is completely black. No options.. Also, I have my phone connected to play music via blutooth, and I need to get into the AUX mode to do this.. If I press the "Phone" button, the bluetooth works perfect. I can make some calls, see my agenda, etc. So, the BT connection is working fine. I think that the problems is only with the AUX menu, to play music from my phone or USB. Is there some "setup file" that I can install in Sync to try to get it working again? Thanks a lot. Regards. Quote Link to comment Share on other sites More sharing options...
Zico Posted February 15, 2022 Share Posted February 15, 2022 On 2/14/2022 at 11:36 AM, Hugo Santini said: Hi Zico, thanks for your response. A few months ago, when I press the AUX Button, I could see the AUX menu. Today, the screen is completely black. No options.. Also, I have my phone connected to play music via blutooth, and I need to get into the AUX mode to do this.. If I press the "Phone" button, the bluetooth works perfect. I can make some calls, see my agenda, etc. So, the BT connection is working fine. I think that the problems is only with the AUX menu, to play music from my phone or USB. Is there some "setup file" that I can install in Sync to try to get it working again? Thanks a lot. Regards. I don't think Sync has anything to do with AUX. You could try pulling the fuse out for the radio and bluetooth modules to reset them. Check your car manual for the correct fuses. I haven't used AUX mode with my phone so can't really help much more than that. Quote Link to comment Share on other sites More sharing options...
Hugo Santini Posted February 15, 2022 Share Posted February 15, 2022 Hello Zico. Ok, thanks. I saw a video with an example about how AUX mode works with the BT audio. I share it here. Hope someone can help me. I think tha its a software issue, but I have note a "sync 1.0 install file" to test. Thanks again! Regards Quote Link to comment Share on other sites More sharing options...
Zico Posted February 16, 2022 Share Posted February 16, 2022 @Hugo Santini if things were working, and now since stopped, resetting the bluetooth sync module / radio might fix things. I don't think you would need to update the sync software. You could also try removing and repairing the phone after resetting. The sync 1.1 download in my post futher up is unlikely to work on sync 1.0. If you download it and extract the files onto a USB stick then your car will probably not recognise any compatible software when you try to update. If you had a VIN for a similar make/model then you could try and get the sync software from the Ford UK site: Ford SYNC & Maps Updates - Check For Updates | Ford UK Quote Link to comment Share on other sites More sharing options...
Hugo Santini Posted February 16, 2022 Share Posted February 16, 2022 Hi Zico! I already reset the Sync module (I took out the correct fuse for 15 min aprox), but the problem continue. The same. I already check for any update in the Ford site, but there is not any file available (Theoretically I have the last version installed). See the image below. It is very strange. I think the only solution is reinstall the original version of Sync 1.0, but my ford Agency does not have the file.. Ay ay ay..... 1 Quote Link to comment Share on other sites More sharing options...
Zaki Posted July 24, 2022 Share Posted July 24, 2022 On 8/1/2022 at 19:40, Zico said: Ciao@Smeig Ricaricherò il file. Link https://files.fm/u/q8bgsjm76 - in fase di caricamento ma dovrebbe essere pronto a breve. Dear Mr. Zico! I'm sorry, but I was late to download the files before the expiration date. Would you please re-up the 5.11 files? THANKS YOU! Sorry for my bad English. Il 16/2/2022 alle 01:27, Zico ha detto: @Ugo Santini se le funzioni cosessero e ora si sono fermate, il ripristino del modulo di sincronizzazione / radio Bluetooth potrebbe risolvere le cose. Non credo che avresti bisogno di aggiornare il software di sincronizzazione. anche provare a rimuovere e riparare il telefono dopo il ripristino. È probabile che il download di sincronizzazione 1.1 nel mio post più avanti funzioni su sincronizzazione 1.0. Se lo scarichi ed estrai i file su una chiavetta USB, la tua auto probabilmente non riconoscerà alcun software compatibile quando tenti di aggiornare. Se avevi un VIN per una marca/modello simile, puoi provare a ottenere il software di sincronizzazione dal sito Ford UK: Ford SYNC & Maps Updates - Check For Updates | Ford Regno Unito Quote Link to comment Share on other sites More sharing options...
Zaki Posted July 24, 2022 Share Posted July 24, 2022 On 16/2/2022 at 01:27, Zico said: @Ugo Santini se le cose funzionassero e ora si sono fermate, il ripristino del modulo di sincronizzazione / radio Bluetooth potrebbe risolvere le cose. Non credo che avresti bisogno di aggiornare il software di sincronizzazione. Potresti anche provare a rimuovere e riparare il telefono dopo il ripristino. È improbabile che il download di sincronizzazione 1.1 nel mio post più avanti funzioni su sincronizzazione 1.0. Se lo scarichi ed estrai i file su una chiavetta USB, la tua auto probabilmente non riconoscerà alcun software compatibile quando tenti di aggiornare. Se avevi un VIN per una marca/modello simile, puoi provare a ottenere il software di sincronizzazione dal sito Ford UK: Ford SYNC & Maps Updates - Check For Updates | Ford Regno Unito Dear Mr. Zico! I'm sorry, but I was late to download the files before the expiration date. Would you please re-up the 5.11 files? THANKS YOU! Sorry for my bad English. Quote Link to comment Share on other sites More sharing options...
Zaki Posted July 24, 2022 Share Posted July 24, 2022 On 8/1/2022 at 19:40, Zico said: Ciao@Smeig Ricaricherò il file. Link https://files.fm/u/q8bgsjm76 - in fase di caricamento ma dovrebbe essere pronto a breve. Dear Mr. Zico! I'm sorry, but I was late to download the files before the expiration date. Would you please re-up the 5.11 files? THANKS YOU! Sorry for my bad English. Quote Link to comment Share on other sites More sharing options...
Zico Posted July 25, 2022 Share Posted July 25, 2022 https://files.fm/u/jzg3ft6v7 Quote Link to comment Share on other sites More sharing options...
creatoro Posted October 18, 2022 Share Posted October 18, 2022 Hi Zico, Could you please reupload? Thanks a lot! Quote Link to comment Share on other sites More sharing options...
Zico Posted October 22, 2022 Share Posted October 22, 2022 On 10/18/2022 at 8:35 AM, creatoro said: Hi Zico, Could you please reupload? Thanks a lot! https://files.fm/u/6aay97dc7 Quote Link to comment Share on other sites More sharing options...
Dan4096 Posted January 7 Share Posted January 7 On 10/22/2022 at 7:32 PM, Zico said: https://files.fm/u/6aay97dc7 G'day, I have been looking all over for update files for my wife's Fiesta... would you mind re-uploading the file please @Zico? Quote Link to comment Share on other sites More sharing options...
Dan4096 Posted January 7 Share Posted January 7 (edited) double-up post due to forum blocking my registration via VPN Edited January 7 by Dan4096 double-up Quote Link to comment Share on other sites More sharing options...
Zico Posted January 21 Share Posted January 21 On 1/7/2023 at 9:23 AM, Dan4096 said: G'day, I have been looking all over for update files for my wife's Fiesta... would you mind re-uploading the file please @Zico? Sorry not been on the forum for a while but files re-uploaded. https://files.fm/u/w7bjx5n9y Quote Link to comment Share on other sites More sharing options...
dan2007h Posted May 24 Share Posted May 24 Hi @Zico, I just got a Sync 1.1 D1BT module and need the correct 5.11 update. would you be able to send me or post an updated link to the file please, I can’t find it anywhere else. Thanks 🙂 really appreciate it. Quote Link to comment Share on other sites More sharing options...
