Sync 1.1 update AppLink
1 hour ago, Zico said:
Re-uploading the file as we speak. Will edit post when done.
The likelihood is that the Ford's download has the typo's on the filenames which is partly why it doesn't work. The uploaded file has simply had the filenames corrected.
**Edit** Link is good for 2 months:
https://files.fm/u/f9w36mpq
Zico
What were the typos? I can only see one slight difference in the(the one that will not work)download i got from Ford with my VIN yesterday and the one you have posted. Am i missing something blindingly obvious when comparing them?
  • Replies 76
  • Views 121.8k
  • I've re-uploaded the 5.11 update here: https://files.fm/u/k2kgtccp The LST files were fixed and all files should be extracted to the root of the USB stick (it's in a folder but the edited LST fil
  • @welshysss re-uploading now. Will post the link when done. **Edit** Done: https://files.fm/u/cg2kbca9
  • @pin8all this link is still active: https://files.fm/f/kv2e9bwx See this post for the re-upload. Good for 2 months from the date of upload:
Well I copied the files onto a newly formatted USB.
Started engine and put in USB. Went to install sync and it started.
Now I'm sat here after 10minutes and nothing seems to be happening.
No messages apart from SYNC Set at the top of the screen.
Is it done? I cant select anything like system info to see if its changed.
**Ignore** Just re-read your post and see that it started installing.
If it's started to install it will take a minimum of 25 minutes before it finishes. Keep the engine running and the system will say when it's restarting and finished.
Zico
You are star. Its installed and updated to 5.11.
My stereo is now correctly bluetooth connecting to my android and my music is playing once again.
Thankyou very much.
The two previous times I updated Sync I did need to re-pair my phone so you may be fortunate. I'm not sure why but guess the updates may have caused me a glitch.
repair your phone? how?
I meant I had to delete the phone from the bluetooth devices and re-add it.
Oh yeah i get ya. Mine just reconnected. So I'm very happy.
Cheers again.
All fine thanks.Updated on the drive to work. No problems at all. Can you tell me what is dfferent in this update compared to the 5.8 version I was on? Thanks again for your help.
@Sasqwatch not entirely sure to be honest. I think it was just some bug fixes and compatibility updates. Nothing more exciting that that. There is no readme in the Ford download.
  • 4 weeks later...
I’ve just used this and it worked perfectly - on v5.11 now. Thank you! Not sure what it means, but at least it’s up-to-date haha
Great I have a 65 plate as well hope this works been trying to update for months I have up in the end
  • 3 weeks later...
Hi just wondering when it's updating can I still drive the car as I could update the system whilst driving to work as the engine needs to be on for about 30 mins or can you not use the car whilst updating. I know the stereo won't play music whilst updating?
After updating my Sync 1 it hasnt got stuck again. Before that I had to disconnect the sync fuse because of my Bluetooth got stuck/didn't work suddenly. Haven't seen any other changes related to update.
Hi Neil, yes you can drive to work while the system updates and use the radio as well. The system will restart sync a few times and tell you when it's done which is normally around 25 minutes.
  • 2 months later...
hey guys i also have the ford files and they dont work. Can you please re upload the correct files for me. I download this file from ford SYNC1.1_768935024_Update extract to the root of the flash, and when i click the install on sync in car, it just says no software found. I think my files also have errors in the names like you say.. If i could please get the proper files.
  • 7 months later...
@Zico is there any chance you could upload the file again please? I’ve bought 2 different USBs (one 3.0 and one 2.0), unzipped using 7-zip, checked the .lst files are separated and no joy! I’ve got a 65 plate fiesta so hoping your files work! Thanks so much!
Hi @Kimbey sorry haven't been on the forum for a few days. The file is currently uploaded here until the 3rd August.
https://files.fm/u/777mpudfz
I did mine and it took 3 different USB sticks till I found one that worked. An old USB2.0 16gb in FAT32 was the only one. What a palaver. Anyway, I left it to it while I went for a drive and just finished my McD in the car park when it finished. Perfect timing. 5.11 sorted. Updated the Sat nav with a V11 SD card and that took nearly as long but all done and happy days.
@Marky146I also found that the car was fussy over which USB stick I used. USB 3.0 should in theory be fine but USB 2.0 worked for me as well.
  • 3 weeks later...
Thanks Zico for resharing, I upgraded my sync 1.0 to a 1.1 BT module so Ford didn't supply any relevant download based upon VIN, your files were the life saver! 🤘🏽
  • 2 months later...
@Zico I hate to ask, but... Would you please re-up the 5.11 files? THANKS!
File is re-uploaded - https://files.fm/u/nyyfpw3r6
Thanks again, Zico!
