voodooirl Posted April 12, 2019 Share Posted April 12, 2019 hi i have a 2008 ford mondeo 1.8 tdci titanium the sony dab radio radio doesnt turn on or off with the key.i have tried to remove the fuse and entered the code but still no luck. also the dashboard isnt showing the radio channels it only shows 2 options settings and trip computer the voice button on the stalk does nothin. anyone any ideas. ive scanned it wit fordsys i got 2 codes p006c which im not worried about but the other one i got was C28AA dont know what this one is. https://1drv.ms/u/s!AqP_mdHb1GdQkxtecFsXE6VM7oiS https://1drv.ms/u/s!AqP_mdHb1GdQkxrlL_56otszKPYb any help would be great thanks Quote Link to comment Share on other sites More sharing options...
Luke4efc Posted April 12, 2019 Share Posted April 12, 2019 C28AA isn't a DTC 1 Quote Link to comment Share on other sites More sharing options...
voodooirl Posted April 12, 2019 Author Share Posted April 12, 2019 ok thanks Quote Link to comment Share on other sites More sharing options...
Mark M Posted April 12, 2019 Share Posted April 12, 2019 The problem is the stereo is no longer talking to the car so the dashboard won't display any radio info because it doesn't know the radio is there. As for why that's happened I don't know, I see you've tried pulling the radio fuse but have you tried disconnecting the battery itself for a few minutes? Quote Link to comment Share on other sites More sharing options...
voodooirl Posted April 12, 2019 Author Share Posted April 12, 2019 only got the car today.i disconnected the positive cable only ill completely disconnect it 2morrow cheers Quote Link to comment Share on other sites More sharing options...
voodooirl Posted April 13, 2019 Author Share Posted April 13, 2019 (edited) 16 hours ago, Mark M said: The problem is the stereo is no longer talking to the car so the dashboard won't display any radio info because it doesn't know the radio is there. As for why that's happened I don't know, I see you've tried pulling the radio fuse but have you tried disconnecting the battery itself for a few minutes? disconnected both terminals on the battery no luck tho. maybe im doing it wrong do i need to leave positive terminal on and disconnect the negative the trip meter hasnt reset tho but clock did also when i entered my radio code the channels where all still stored? any more ideas guys thanks Edited April 13, 2019 by voodooirl 1 Quote Link to comment Share on other sites More sharing options...
gg1234635 Posted April 13, 2019 Share Posted April 13, 2019 might be worth you looking into a program called Forscan. It might give you some error codes so you can look up what the problem. www.forscan.org 1 Quote Link to comment Share on other sites More sharing options...
Luke4efc Posted April 16, 2019 Share Posted April 16, 2019 On 4/13/2019 at 2:57 PM, voodooirl said: maybe im doing it wrong do i need to leave positive terminal on and disconnect the negative It's generally best practice to remove the negative terminal. On 4/13/2019 at 2:57 PM, voodooirl said: the trip meter hasnt reset tho but clock did also when i entered my radio code the channels where all still stored? Yes this all happened on my Focus when I changed the battery. I was quite surprised the radio held its channels tbh. Quote Link to comment Share on other sites More sharing options...
FatHead1979 Posted April 29, 2019 Share Posted April 29, 2019 On 4/16/2019 at 5:28 PM, Luke4efc said: It's generally best practice to remove the negative terminal. Yes this all happened on my Focus when I changed the battery. I was quite surprised the radio held its channels tbh. Although both methods will achieve the same thing. Quote Link to comment Share on other sites More sharing options...
Afa82 Posted December 31, 2019 Share Posted December 31, 2019 I have this same problem....anybody solve it yet? 1 Quote Link to comment Share on other sites More sharing options...
Kllaaa Posted May 13, 2020 Share Posted May 13, 2020 Also same problem.. 1 Quote Link to comment Share on other sites More sharing options...
Gh2410 Posted October 3, 2020 Share Posted October 3, 2020 Hi. Has this radio issue been resolved yet? I have the same problem. 1 Quote Link to comment Share on other sites More sharing options...
Krapu Posted October 23, 2020 Share Posted October 23, 2020 Any one sort out this issue??? I have this problem to! FORD MONDEO MK4! First time I had problems with wipers...doesn't stop from controller .... and now with the radio... is a electric problem but I don't know where. 1 Quote Link to comment Share on other sites More sharing options...
Sid1979 Posted December 12, 2020 Share Posted December 12, 2020 Same issue anyone got a fix. 1 Quote Link to comment Share on other sites More sharing options...
Liamdd Posted April 30, 2021 Share Posted April 30, 2021 I have the same problem . Tried out ion test light to all wires on the back of the radio and seams like no power. any one know which the power lead (colour wire) it should be going to the back 2009 titanium x, Sony cd 1 Quote Link to comment Share on other sites More sharing options...
iantt Posted April 30, 2021 Share Posted April 30, 2021 Brown/red. Should supply power via fuse f6 in footwell fusebox. Quote Link to comment Share on other sites More sharing options...
Keithhemp Posted May 14, 2021 Share Posted May 14, 2021 Did any one get this issue fixed got same problem. Read on Google about pulling fuse f6 then refit.didnt work. 1 Quote Link to comment Share on other sites More sharing options...
A moate Posted September 21, 2021 Share Posted September 21, 2021 Take the front of radio heat up with heat gun 30 secs put back on sorted mine 1 Quote Link to comment Share on other sites More sharing options...
Hexham des Posted March 16, 2022 Share Posted March 16, 2022 h Had the same problem. Changed ignition switch (£22) working great now. Quite a simple job too. Quote Link to comment Share on other sites More sharing options...
Bristshowboy Posted October 31, 2023 Share Posted October 31, 2023 I have a very sticky on / off switch on the radio… possibly something to do with that. I manually have to pull it out, to get it to work again. Occasionally forget and find the radio keeps turning itself (& digital systems in the car) back on. Car is 2017 smax vignale - Sony radio. Quote Link to comment Share on other sites More sharing options...
jammy1919 Posted March 12 Share Posted March 12 I've just had the same problem. EASY FIX HOLD THE OFF/ON BUTTON FOR 20 SECONDS. THE RADIO RESETS. Quote Link to comment Share on other sites More sharing options...
