TimST2
Autoglym binge
Got 15% off this lot in Halfords today with my FOC card
4c3dee8cc2d6ed120be4c53c693ddced.jpg&key=5a8760a97a80357a01e846793de193f89fde763add6a60d54b55aa0804c46728
Also going to try the Autoglym Polar Blast snow foam for the first time as it's half the price of the Auto Finesse Avalanche I have been using...
73effe8b782e606138ac1453ece76886.jpg&key=0bab92ef2c608fff6dec2ba7f9463ecf55871639de48199093136f3ce05c4281
I'm about to get some Polar Blast too as I was given a £10 Halfords voucher. should be good.
Tbh I think snow foam is a complete waste of time and money. It never seems to clean the car anymore than what a normal jetwash would do. Having said that I still use it every time because it looks awesome haha. The polar blast is the thickest one I've used so far imo. All the others just seem to run off the car quite fast so gave up on them.
I'd also recommend the polar seal. It makes the water bead up like mad, but also lasts for ages (I tend to reapply every month, but takes seconds once you have the bottle filled). You use very little each time too, about 40ml to 300ml of water is enough for the whole car. That means if you use it once a month, you've enough in the bottle to last over 2 years! (which tbh is probably a bit too frequently. The water still beads up like mad after 6 weeks. I could probably get away with just giving my car a quick snow foam and rinse every week now to keep it clean after using this stuff.
I'd not heard of Polar Seal. It looks like it's an alternative to Aqua Wax. How does it compare?
Yes, however instead of applying it with cloths, you just load it into your foam cannon and spray all over the car. Leave it for a few seconds till you hear it 'hissing' and jetwash off. Its miles faster than waxing and leaves quite a durable finish.
How would you rate how much it protects the paintwork in comparison to a layer of Aqua Wax?
I believe it's just like any other sealant in the way it protects the paint. I'd say it's probably the same level of protection as waxing, but the polar seal lasts a lot longer before needing to be reapplied.
I've since read that you shouldn't apply more than once a month as it can cause worse results (due to build of of product). Most people probably do it every 2-3 months depending on how much crap the car collects.
Have you tried out the autoglym polar sealant? Thinking of getting this. Looks a lot easier and faster to apply compared to putting a wax on by hand.
Do you mean the stuff I've been talking about in all my replies? 😂😉
Sorry luke, didn't see that 😂. Just excited at the moment as I bought something for the car. Just hope the paperwork goes through nicely.
Will have a look at that stuff. Saves the hassle of braking my back applying wax by hand. Saves a hour of cleaning
Well with Aqua Wax you spray it on the wet car before you dry it so it's not a lot different.
Here's what the Autoglym FAQ says about Polar Seal vs wax:
Quote
Is Polar Seal wax safe?
Polar Seal is wax safe and we would recommend that if there is wax on the paintwork that Polar Seal is used as a top up. There is no need to remove the wax or other protection before applying Polar Seal.
Do I use Polar Seal instead of a wax?
Polar Seal is a durable hydrophobic coating. However, it does not offer the same long-term protection as Ultra High Definition Wax or Extra Gloss Protection.
How frequently do I need to apply Polar Seal?
There is no benefit to building layers of Polar Seal. We would only recommend reapplication once water beading has ceased. We certainly do not recommend application more than once a month.
So no need to apply so often but not as protective? I certainly build up layers of Aqua Wax as I use it every wash and it's worked really well over the years...
  Only 75 emoji are allowed.
