Heleas03 Posted July 24, 2019 Share Posted July 24, 2019 Hello everyone, Can you help me I'm stuck. So, I took out the glove box and cleared the way to my pollen filter door, BUT, some kind of aluminium pipe goes across the way and I cannot take out the pollen filter door. Any idea what should I do? (The car has AC). Also I tried at the other side where the pedals are but without any success. There are three hex nuts holding the gas pedal, one at the bottom and two at the top, but I cannot reach the top ones. Any idea ? Thanks in advance! Quote Link to comment Share on other sites More sharing options...
FatHead1979 Posted July 24, 2019 Share Posted July 24, 2019 Is the car left hand drive? Quote Link to comment Share on other sites More sharing options...
TomsFocus Posted July 24, 2019 Share Posted July 24, 2019 Assuming it is LHD, you just need to find a suitable tool to reach the throttle pedal nuts. Quote Link to comment Share on other sites More sharing options...
Heleas03 Posted July 24, 2019 Author Share Posted July 24, 2019 Its left hand drive. So I need to go from the pedals side not the glove box? Quote Link to comment Share on other sites More sharing options...
TomsFocus Posted July 24, 2019 Share Posted July 24, 2019 1 hour ago, Heleas03 said: Its left hand drive. So I need to go from the pedals side not the glove box? Yes, the filter will only come out of the pedals side due to the pipes on the other side as you've seen. Quote Link to comment Share on other sites More sharing options...
Heleas03 Posted July 24, 2019 Author Share Posted July 24, 2019 Thanks, guys, I give it a try with some tool combinations Quote Link to comment Share on other sites More sharing options...
Ned_Mk2_1.8tdci Posted July 25, 2019 Share Posted July 25, 2019 You need a deep 10 mm socket to remove gas pedal bolts. Also you need 7 mm socket to remove the screws from the lid of the filter box. Be careful, do not unplug the gas pedal connector (Ford Repair Manual limits this to 10 times, after you need new gas pedal). Try to push it upward and fix it somehow. Remove the filter by bending it outwards, try not to touch connector wires. In total 30-45 min job. 1 Quote Link to comment Share on other sites More sharing options...
Heleas03 Posted July 29, 2019 Author Share Posted July 29, 2019 Thank you mate, helped a lot! Quote Link to comment Share on other sites More sharing options...
