mrmetallica Posted March 10, 2020 Share Posted March 10, 2020 ive been searching for how toos on the above but cant find owt any no where it is ? Quote Link to comment Share on other sites More sharing options...
WireyWhenWet Posted March 11, 2020 Share Posted March 11, 2020 The LEDs in almost all switches require soldering to remove and replace with other colours, whilst in order to do so the switches themselves will require removal and careful disassembly. Some are easier to get to, remove and disassemble than others, but they're so varied and you have to err on the side of caution with regards to resistance values as going overboard could result in drawing too much or too little current from one circuit which can have some impact - Red for example will pull less power than Green, but it all depends what you want to do and given the copious amounts of combinations you might be hard pressed to find an easy guide that covers enough to keep things basic and risk free. Which in particular are you wanting to swap out? 2 Quote Link to comment Share on other sites More sharing options...
mrmetallica Posted March 11, 2020 Author Share Posted March 11, 2020 1 hour ago, WireyWhenWet said: The LEDs in almost all switches require soldering to remove and replace with other colours, whilst in order to do so the switches themselves will require removal and careful disassembly. Some are easier to get to, remove and disassemble than others, but they're so varied and you have to err on the side of caution with regards to resistance values as going overboard could result in drawing too much or too little current from one circuit which can have some impact - Red for example will pull less power than Green, but it all depends what you want to do and given the copious amounts of combinations you might be hard pressed to find an easy guide that covers enough to keep things basic and risk free. Which in particular are you wanting to swap out? i want to change them to blue. im sure ive seen a how to some where Quote Link to comment Share on other sites More sharing options...
F0CUE Posted March 12, 2020 Share Posted March 12, 2020 This one maybe? 1 Quote Link to comment Share on other sites More sharing options...
StephenFord Posted March 12, 2020 Share Posted March 12, 2020 18 minutes ago, F0CUE said: This one maybe? That is one awful amount of work, to change colour! Quote Link to comment Share on other sites More sharing options...
F0CUE Posted March 12, 2020 Share Posted March 12, 2020 1 hour ago, StephenFord said: That is one awful amount of work, to change colour! Agreed 😃 Quote Link to comment Share on other sites More sharing options...
mrmetallica Posted March 12, 2020 Author Share Posted March 12, 2020 5 hours ago, F0CUE said: This one maybe? ive done the speedo but was sure there was a how to on the switches mainly for the sizes of the leds mainly not so much how to Quote Link to comment Share on other sites More sharing options...
WireyWhenWet Posted March 13, 2020 Share Posted March 13, 2020 On 3/12/2020 at 1:53 PM, mrmetallica said: ive done the speedo but was sure there was a how to on the switches mainly for the sizes of the leds mainly not so much how to Ahh gotcha. Unfortunately I'm not sure on that one (yet..) but it's something I'm looking at in the bear future; if it manage to get round to it on mine I'll make a guide but it's not quite the top of my list at the moment. 1 Quote Link to comment Share on other sites More sharing options...
mrmetallica Posted March 13, 2020 Author Share Posted March 13, 2020 1 hour ago, WireyWhenWet said: Ahh gotcha. Unfortunately I'm not sure on that one (yet..) but it's something I'm looking at in the bear future; if it manage to get round to it on mine I'll make a guide but it's not quite the top of my list at the moment. i just find it hard working out what leds to use. was there not a how to on hear before ? Quote Link to comment Share on other sites More sharing options...
WireyWhenWet Posted March 13, 2020 Share Posted March 13, 2020 The only one I've come across recently when looking has been this one. I vaguely remember seeing something else quite some time ago, but I can't seem to find it. 1 Quote Link to comment Share on other sites More sharing options...
mrmetallica Posted March 13, 2020 Author Share Posted March 13, 2020 1 hour ago, WireyWhenWet said: The only one I've come across recently when looking has been this one. I vaguely remember seeing something else quite some time ago, but I can't seem to find it. yeah i found that one Quote Link to comment Share on other sites More sharing options...
F0CUE Posted March 14, 2020 Share Posted March 14, 2020 There is always modified blue ones on eBay. No luck finding any guides only coming across with later versions or MK1. 1 Quote Link to comment Share on other sites More sharing options...
mrmetallica Posted March 14, 2020 Author Share Posted March 14, 2020 21 minutes ago, F0CUE said: There is always modified blue ones on eBay. No luck finding any guides only coming across with later versions or MK1. same hear never mind ill just have to work out the sizes my self cheers Quote Link to comment Share on other sites More sharing options...
