Dab ariel
I'm hoping someone can help
I need a dab ariel with the fitting the same as this but I'm not sure what the fitting is called. The one from Halfords doesn't seem to be this connector. Can anyone advise?
Also can and tone advise best place to fit the ariel as have heated front and rear screens
that looks like F type you find on your home satellite box.   But in a miniature size  ?  you used to see this on OLD GPS stuff, I think your stuffed.  You often find SMB rubbish that's incompatible with those manufacturers use
all car manu use fakra connectors these days - adapting between type ought to be so simple but I've never found any.... although SMB can be ground back and fits the fakra stuff with less security
Looks like this when disconnected
That looks like a push fit connector
Description states its a screw type connection
Looks like I've got an sma connector?
Where is the best place to fit due to heated front and rear screens?
Rear quarter window would probably be best.
Nice, hadn't thought of that, thank you
ooh, there's more here than I thought
https://incartec.co.uk/category-listing/DAB-antennas-and-adapters
not cheap but they use the right names and post things quick (normally - not sure where they are re covid)
