Mhamill66 Posted June 4, 2020 Share Posted June 4, 2020 Hi all, So today I noticed a pool of green fluid on the floor under my car. I had a look underneath and can see that its coming through a hole under the car..... how that got there I dont know! It's passenger side at the very front of the car. Any ideas what it could be? (Sorry for the combined images, apparently I cant upload single images, file size is too big) Any help would be greatly appreciated! Thank you, Mike. Quote Link to comment Share on other sites More sharing options...
The Finance Guy Posted June 4, 2020 Share Posted June 4, 2020 Green will be coolant. Radiator sprung a leak, or a split hose maybe coming off the radiator. Quote Link to comment Share on other sites More sharing options...
Mhamill66 Posted June 4, 2020 Author Share Posted June 4, 2020 On a scale of 1 to 10, how screwed/expensive is this going to be? Quote Link to comment Share on other sites More sharing options...
Lenny Posted June 4, 2020 Share Posted June 4, 2020 Just now, Mhamill66 said: On a scale of 1 to 10, how screwed/expensive is this going to be? Not a huge amount well not over 150 pounds worse case being a replacement radiator and ofcourse fluid, That's if you source the issue yourself, but would increase when involving a mechanic or main stealer. Eh that's not a type error 😂 It wont drive far without coolant before overheating neither, Best outcome is a split hose worded outcome it a weld fracture on the radiator Quote Link to comment Share on other sites More sharing options...
Milkman Posted June 4, 2020 Share Posted June 4, 2020 If you are with one of the rescue services drive it around the corner and give them a call. Quote Link to comment Share on other sites More sharing options...
